Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Scratch Built Kwik Fli III
Old 01-08-2018, 06:45 AM
  #101
FlyerInOKC
FlyerInOKC's Avatar
That is a lot of orange! Even as half blind as I am I could see it in the air!
Old 01-09-2018, 02:23 AM
  #102
erans
Some colour and trim...
Eran
Name:	2017_09_01 01 Kwik Fli 3 Covering.JPG
ID:	2250506   Click image for larger version
Name:	2017_09_01 02 Kwik Fli 3 Covering.JPG
ID:	2250507   Click image for larger version
Name:	2017_09_01 03 Kwik Fli 3 Covering.JPG
ID:	2250508   Click image for larger version
Name:	2017_09_01 04 Kwik Fli 3 Covering.JPG
ID:	2250509   Click image for larger version
Name:	2017_09_02 01 Kwik Fli 3 Covering.JPG
ID:	2250510   Click image for larger version
Name:	2017_09_02 02 Kwik Fli 3 Covering.JPG
ID:	2250511   Click image for larger version
Name:	2017_09_02 03 Kwik Fli 3 Covering.JPG
Old 01-09-2018, 06:17 AM
  #103
FlyerInOKC
FlyerInOKC's Avatar
This is going to one very handsome airplane!
Old 01-10-2018, 08:19 PM
  #104
erans
FlyerInOKC - I hope it will make justice to the original.
The most difficult section was the fuselage sides, which had a curved section. I used half section template and flipped it on the center line to have symmetrical shape. Once marked I cut the Monokote.
The vertical fin was also quite challenging, but I think it came out OK.
Eran
Name:	2017_09_04 01 Kwik Fli 3 Covering.JPG
ID:	2250644   Click image for larger version
Name:	2017_09_04 02 Kwik Fli 3 Covering.JPG
ID:	2250645   Click image for larger version
Name:	2017_09_04 03 Kwik Fli 3 Covering.JPG
ID:	2250646   Click image for larger version
Name:	2017_09_04 04 Kwik Fli 3 Covering.JPG
ID:	2250647   Click image for larger version
Name:	2017_09_04 05 Kwik Fli 3 Covering.JPG
ID:	2250648   Click image for larger version
Name:	2017_09_04 06 Kwik Fli 3 Covering.JPG
ID:	2250649   Click image for larger version
Name:	2017_09_04 07 Kwik Fli 3 Covering.JPG
ID:	2250650   Click image for larger version
Name:	2017_09_04 08 Kwik Fli 3 Covering.JPG
Name:	2017_09_04 09 Kwik Fli 3 Covering.JPG
ID:	2250652   Click image for larger version
Name:	2017_09_04 10 Kwik Fli 3 Covering.JPG
ID:	2250653   Click image for larger version
Name:	2017_09_04 11 Kwik Fli 3 Covering.JPG
ID:	2250654   Click image for larger version
Name:	2017_09_04 12 Kwik Fli 3 Covering.JPG
ID:	2250655   Click image for larger version
Name:	2017_09_04 13 Kwik Fli 3 Covering.JPG
ID:	2250656   Click image for larger version
Name:	2017_09_04 14 Kwik Fli 3 Covering.JPG
ID:	2250657   Click image for larger version
Name:	2017_09_04 16 Kwik Fli 3 Covering.JPG
ID:	2250658   Click image for larger version
Name:	2017_09_04 18 Kwik Fli 3 Covering.JPG
Old 01-11-2018, 09:34 AM
  #105
FlyerInOKC
FlyerInOKC's Avatar
Nice!
Old 01-11-2018, 05:59 PM
  #106
erans
Preparing the tail group assembly, the removal of covering wais done with soldering iron to expose the wood. 30 minutes epoxy was used.
Alignment of the horizontal stabiliser was checked and re checked to the wing as reference. The vertical fin was checked to be perfect 90 degree to the horizontal stabiliser and in alignment to the fuselage centre line.
I cut CA hinges for the elevator and rudder, another departure from traditional hinging for both convenience and durability.
Eran
Name:	2017_09_04 20 Kwik Fli 3 Tailplane Prep.JPG
ID:	2250718   Click image for larger version
Name:	2017_09_04 21 Kwik Fli 3 Tailplane Prep.JPG
ID:	2250719   Click image for larger version
Name:	2017_09_05 01 Kwik Fli 3 Tailplane.JPG
ID:	2250720   Click image for larger version
Name:	2017_09_05 02 Kwik Fli 3 Tailplane.JPG
ID:	2250721   Click image for larger version
Name:	2017_09_07 01 Kwik Fli 3 Tail CA Hinges.JPG
ID:	2250722   Click image for larger version
Name:	2017_09_07 02 Kwik Fli 3 Tail CA Hinges.JPG
ID:	2250723   Click image for larger version
Name:	2017_09_07 03 Kwik Fli 3 Tail CA Hinges.JPG
ID:	2250724   Click image for larger version
Name:	2017_09_07 04 Kwik Fli 3 Tail CA Hinges.JPG
Name:	2017_09_07 05 Kwik Fli 3 Tail CA Hinges.JPG
ID:	2250726   Click image for larger version
Name:	2017_09_07 06 Kwik Fli 3 Tail CA Hinges.JPG
ID:	2250727   Click image for larger version
Name:	2017_09_07 07 Kwik Fli 3 Vertical Fin Attachment Prep.JPG
ID:	2250728   Click image for larger version
Name:	2017_09_07 08 Kwik Fli 3 Vertical Fin Attachment Prep.JPG
ID:	2250729   Click image for larger version
Name:	2017_09_07 09 Kwik Fli 3 Vertical Fin Attachment Prep.JPG
ID:	2250730   Click image for larger version
Name:	2017_09_07 10 Kwik Fli 3 Rudder to Elevator Notch.JPG
ID:	2250731   Click image for larger version
Name:	2017_09_07 11 Kwik Fli 3 Rudder to Elevator Notch.JPG
ID:	2250732   Click image for larger version
Name:	2017_09_07 12 Kwik Fli 3 Vertical Fin Attachment.JPG
Name:	2017_09_07 13 Kwik Fli 3 Vertical Fin Attachment.JPG
Old 01-12-2018, 07:10 AM
  #107
FlyerInOKC
FlyerInOKC's Avatar
It won't be long until this bird is ready to fly the coop!
Old 01-12-2018, 10:20 PM
  #108
erans
Gluing the hinges of the rudder and elevator.
Dubro Horns and 2-56 rods, Sullivan Gold-N-Clevises.
Eran
Name:	2017_09_08 01 Kwik Fli 3 Tailplane CA Hinging.JPG
ID:	2250897   Click image for larger version
Name:	2017_09_08 02 Kwik Fli 3 Tailplane CA Hinging.JPG
ID:	2250898   Click image for larger version
Name:	2017_09_08 03 Kwik Fli 3 Tailplane CA Hinging.JPG
ID:	2250899   Click image for larger version
Name:	2017_09_08 04 Kwik Fli 3 Tailplane CA Hinging.JPG
ID:	2250900   Click image for larger version
Name:	2017_09_08 05 Kwik Fli 3 Tailplane Link.JPG
ID:	2250901   Click image for larger version
Name:	2017_09_08 06 Kwik Fli 3 Tailplane Link.JPG
ID:	2250902   Click image for larger version
Name:	2017_09_08 07 Kwik Fli 3 Tailplane Link.JPG
ID:	2250903   Click image for larger version
Name:	2017_09_08 08 Kwik Fli 3 Tailplane Link.JPG
Name:	2017_09_08 09 Kwik Fli 3 Wing Servo Leads Exit.JPG
ID:	2250905   Click image for larger version
Name:	2017_09_08 10 Kwik Fli 3 Ail Link.JPG
ID:	2250906   Click image for larger version
Name:	2017_09_08 11 Kwik Fli 3 Ail Link.JPG
Old 01-14-2018, 05:16 PM
  #109
erans
Bending of the main landing gear, mounting the front landing gear leg, plumbing the fuel tank and mounting the dedicated steering servo.
Eran
Name:	2017_09_11 01 Kwik Fli III Wire Bender Prep.JPG
ID:	2251121   Click image for larger version
Name:	2017_09_11 02 Kwik Fli III Landing Gear.JPG
ID:	2251122   Click image for larger version
Name:	2017_09_11 03 Kwik Fli III Landing Gear.JPG
ID:	2251123   Click image for larger version
Name:	2017_09_11 04 Kwik Fli III Landing Gear.JPG
ID:	2251124   Click image for larger version
Name:	2017_09_11 05 Kwik Fli III Landing Gear.JPG
ID:	2251125   Click image for larger version
Name:	2017_09_11 06 Kwik Fli III Landing Gear.JPG
ID:	2251126   Click image for larger version
Name:	2017_09_11 07 Kwik Fli III Landing Gear.JPG
ID:	2251127   Click image for larger version
Name:	2017_09_11 08 Kwik Fli III Landing Gear.JPG
Name:	2017_09_11 09 Kwik Fli III Landing Gear.JPG
ID:	2251129   Click image for larger version
Name:	2017_09_11 10 Kwik Fli III Fuel Tank.JPG
ID:	2251130   Click image for larger version
Name:	2017_09_11 11 Kwik Fli III Stearing Servo.JPG
Old 01-15-2018, 06:27 AM
  #110
FlyerInOKC
FlyerInOKC's Avatar
What is the purpose of two clunks in the tank?
Old 01-16-2018, 12:51 AM
  #111
erans
FlyerInOKC - The O.S. GGT10 is a pumped petrol engine. The second line with the clunk is used to fill and empty the tank using the Dubro kwik fill. I never use the line going to the engine from the Kwik Fill. The main fuel line go to the pump, then through a filter into the carburettor. The tank cannot be emptied through this line. The air line is not pressurised and is venting out at the bottom of the aeroplane, which also indicates (by spilling fuel) that the tank is full.
I made the rails and tray for the removable fuel tank shelf, and mounted the throttle servo.
Eran
Name:	2017_09_12 01 Kwik Fli 3 Fuel Tank Mounting Rails.JPG
ID:	2251349   Click image for larger version
Name:	2017_09_12 02 Kwik Fli 3 Fuel Tank Bay Removable Floor.JPG
ID:	2251350   Click image for larger version
Name:	2017_09_12 03 Kwik Fli 3 Throttle Servo.JPG
ID:	2251351   Click image for larger version
Name:	2017_09_12 04 Kwik Fli 3 Throttle Servo Mount.JPG
ID:	2251352   Click image for larger version
Name:	2017_09_12 05 Kwik Fli 3 Throttle Servo Mount.JPG
ID:	2251353   Click image for larger version
Name:	2017_09_12 06 Kwik Fli 3 Throttle Servo.JPG
Old 01-16-2018, 05:59 AM
  #112
FlyerInOKC
FlyerInOKC's Avatar
It's really looking good! I like the Dubro kwik fill but have never used a seperate fill line, what are the advantages of not using the the line to the carb and are they the same for glow?
Old 01-17-2018, 03:30 AM
  #113
erans
FlyerInOKC - I had two Dubro Large Scale Kwik Fill Fueling Valve (Item #611 - gas) that were leaking air into the fuel line. Since then, I keep my fuel feed as simple as possible, with only a filter between the clunk and the entry to the carburettor.
I completed the removable "shelve" from scrap wood for the fuel tank, mounted the pump and got the fuel system connected.
Eran
Name:	2017_09_18 01 Kwik Fli 3 Fuel Tank Shelve.JPG
ID:	2251416   Click image for larger version
Name:	2017_09_18 02 Kwik Fli 3 Fuel Tank Shelve.JPG
ID:	2251417   Click image for larger version
Name:	2017_09_18 03 Kwik Fli 3 Fuel System.JPG
ID:	2251418   Click image for larger version
Name:	2017_09_18 04 Kwik Fli 3 Fuel System.JPG
ID:	2251419   Click image for larger version
Name:	2017_09_18 05 Kwik Fli 3 Fuel System.JPG
ID:	2251420   Click image for larger version
Name:	2017_09_18 06 Kwik Fli 3 Fuel System.JPG
ID:	2251421   Click image for larger version
Name:	2017_09_18 07 Kwik Fli 3 Fuel System.JPG
ID:	2251422   Click image for larger version
Name:	2017_09_18 08 Kwik Fli 3 Fuel System.JPG
Old 01-19-2018, 05:17 AM
  #114
erans
I got the throttle arm, Muffler and Spinner sorted. The throttle arm required me to remove some balsa to allow free movement for the ball link. The spinner required a thick backplate to properly clear the front due to my miscalculation when mounting the engine.
I then glued the canopy into place.
Eran
Name:	2017_09_20 01 Kwik Fli 3 Throttle Attachment.JPG
ID:	2251554   Click image for larger version
Name:	2017_09_20 02 Kwik Fli 3 Throttle Attachment.JPG
ID:	2251555   Click image for larger version
Name:	2017_09_20 03 Kwik Fli 3 Throttle Attachment.JPG
ID:	2251556   Click image for larger version
Name:	2017_09_20 04 Kwik Fli 3 Muffler Attachment.JPG
ID:	2251557   Click image for larger version
Name:	2017_09_20 05 Kwik Fli 3 Muffler Attachment.JPG
ID:	2251558   Click image for larger version
Name:	2017_09_21 01 Kwik Fli 3 Spinner Attachment.JPG
ID:	2251559   Click image for larger version
Name:	2017_09_21 02 Kwik Fli 3 Spinner Attachment.JPG
ID:	2251560   Click image for larger version
Name:	2017_09_21 03 Kwik Fli 3 Spinner Attachment.JPG
Name:	2017_09_21 04 Kwik Fli 3 Canopy Attachment.JPG
Old 01-19-2018, 05:55 AM
  #115
FlyerInOKC
FlyerInOKC's Avatar
Eran, it won't be long now! Good work!
Old 01-20-2018, 12:24 AM
  #116
erans
With the Canopy in place and looking good, it is time for the last push.
Lending gear in place, first photos on its own legs. Ready for CG check.
Eran
Name:	2017_09_25 01 Kwik Fli 3 Canopy.JPG
ID:	2251626   Click image for larger version
Name:	2017_09_25 02 Kwik Fli 3 Canopy.JPG
ID:	2251627   Click image for larger version
Name:	2017_09_25 03 Kwik Fli 3 Main LG.JPG
ID:	2251628   Click image for larger version
Name:	2017_09_25 04 Kwik Fli 3 Main LG.JPG
ID:	2251629   Click image for larger version
Name:	2017_09_26 01 Kwik Fli 3 Main LG.JPG
ID:	2251630   Click image for larger version
Name:	2017_09_26 02 Kwik Fli 3 Main LG.JPG
ID:	2251631   Click image for larger version
Name:	2017_09_26 03 Kwik Fli 3 Assembled.JPG
ID:	2251632   Click image for larger version
Name:	2017_09_26 04 Kwik Fli 3 Assembled.JPG
Name:	2017_09_26 05 Kwik Fli 3 Assembled.JPG
ID:	2251634   Click image for larger version
Name:	2017_09_26 06 Kwik Fli 3 Assembled.JPG
ID:	2251635   Click image for larger version
Name:	2017_09_26 07 Kwik Fli 3 Assembled.JPG
Old 01-20-2018, 04:33 AM
  #117
ETpilot
ETpilot's Avatar
Just an observation, I would check that elevator control horn-clevis connection. The clevis is not fully closed. Not sure about the metal clip you have securing the clevis. From the picture, there appears to be an angle between the horn and the clevis causing the clevis to remain slightly open. You sure don't want a problem in this area. A piece of fuel tubing added would certainly help. Just my observation.
Nice build. Looking really good. I like scratch building.
Old 01-20-2018, 11:50 PM
  #118
erans
ETpilot - Thank you for the comment. The Sullivan 2-56 "Gold 'N' Clevises" have the metal clips for securing the clevis, and it has never failed me (going back to the late 1980's...). It has been a while since I used them as most of my aeroplanes are much bigger, but my confident in the product didn't change. It is difficult to remove the metal clip even with tip pliers, not to mention having it removed with your fingers.
I had some time to complete the pre flight stuff in the afternoon. I performed a provisional balance check using the battery, it is obvious that weight will be required at the tail.
This determined the final placement for components with the battery as far back as possible on its newly made tray. The receiver is also reasonably back with the satellite placed away for diversity. The power switch completed the assembly.
Re check of balance and some weight at the tail and wing tip completed the aeroplane, it was ready for test flight.
Eran
Name:	2017_09_26 08 Kwik Fli 3 CG Check.JPG
ID:	2251776   Click image for larger version
Name:	2017_09_26 09 Kwik Fli 3 CG Check.JPG
ID:	2251777   Click image for larger version
Name:	2017_09_26 10 Kwik Fli 3 Batt Tray.JPG
ID:	2251778   Click image for larger version
Name:	2017_09_26 11 Kwik Fli 3 Switch and Batt.JPG
ID:	2251779   Click image for larger version
Name:	2017_09_26 12 Kwik Fli 3 Switch and Batt.JPG
ID:	2251780   Click image for larger version
Name:	2017_09_26 13 Kwik Fli 3 Switch and Batt.JPG
ID:	2251781   Click image for larger version
Name:	2017_09_28 02 Kwik Fli 3 Receiver Satelite.JPG
ID:	2251782   Click image for larger version
Name:	2017_09_28 03 Kwik Fli 3 Receiver.JPG
Name:	2017_09_28 04 Kwik Fli 3 CG Balance.JPG
ID:	2251784   Click image for larger version
Name:	2017_09_28 05 Kwik Fli 3 CG Balance.JPG
ID:	2251785   Click image for larger version
Name:	2017_09_28 06 Kwik Fli 3 CG Balance.JPG
ID:	2251786   Click image for larger version
Name:	2017_09_28 07 Kwik Fli 3 CG Balance.JPG
ID:	2251787   Click image for larger version
Name:	2017_09_29 01 Kwik Fli 3 Wing Weight.JPG
ID:	2251788   Click image for larger version
Name:	2017_09_29 02 Kwik Fli 3 Wing Weight.JPG
Old 01-21-2018, 12:03 AM
  #119
erans
After the obligatory photo session, two successful flights were made. The aeroplane fly well, as expected.
The O.S. GGT10 engine has history of issues (it was bought second hand almost new from a friend) and could not reliably idle, so I called it a day.
This engine was tested on a stand prior to being placed in this aeroplane and worked OK then. So back to a test stand it goes for further evaluation.
The main goal for the project was to produce a classic aerobatic aeroplane which I wanted to have for many years, and this has now been achieved.
Second goal was to build it as close as reasonably possible to the original flown by Phil Kraft (but with modern gear), and I think the photo is a proof that this goal has been achieved.
Cheers,
Eran
Name:	2017_10_01 01 Kwik Fli 3 at WAMASC Maiden Flight Day.JPG
ID:	2251790   Click image for larger version
Name:	2017_10_01 02 Kwik Fli 3 at WAMASC Maiden Flight Day.JPG
ID:	2251791   Click image for larger version
Name:	2017_10_01 03 Kwik Fli 3 at WAMASC Maiden Flight Day.JPG
ID:	2251792   Click image for larger version
Name:	2017_10_01 06 Kwik Fli 3 Replicating Build Article Photo.JPG
ID:	2251793   Click image for larger version
Name:	1968 Kwik Fli III.jpg
Old 01-22-2018, 06:21 AM
  #120
FlyerInOKC
FlyerInOKC's Avatar
Fantastic I think Phil would have approved!
Old 01-23-2018, 04:24 AM
  #121
erans
FlyerInOKC - Thank you, appreciated.
I got the O.S. GGT10 engine back on my engine stand today. After much fiddling, I got it to work much better then I managed at the airfield.
The main breakthrough seems to be the re-introduction of the crankcase "pulse spacer" (a restrictor inside the crankcase line to the pump), against the instructions recommendations.
Once it was back in, the tuning of the mixture control became somewhat effective. Now I can idle the engine quite reliably. Transition is still not great, as I cannot "slam" the throttle after a long idle. However, it won't die if advanced with caution and I cannot find a tuning that works any better, so it is what it is.
I will not have much time to attend to this aeroplane in the coming week or two, so I will update when I have news.
Eran
Name:	2018_01_23 01 GGT10 running on Engine Stand.JPG
ID:	2251979   Click image for larger version
Name:	2018_01_23 02 GGT10 running on Engine Stand.JPG
ID:	2251980   Click image for larger version
Name:	2018_01_23 03 GGT10 running on Engine Stand.JPG
Old 01-23-2018, 06:31 AM
  #122
youngguy
My Feedback: (7)
youngguy's Avatar
Really enjoyed your KwikFli build. Built a number of these in the late 60s early 70s both from kits and plans for myself and others. Great flying model. Brought back a lot of good memories and might just inspire me to another.
Old 01-23-2018, 06:35 AM
  #123
FlyerInOKC
FlyerInOKC's Avatar
Cool! I'm anxious to see how she runs when you get it back in the airplane.
Old 01-23-2018, 03:57 PM
  #124
erans
youngguy - This was a fun build. If the limited flying I had is an indication, then it is a great flying aeroplane. My build already inspired a friend of mine to build one (he is 50% through). like you, he built one or two of them in the early 70's.
FlyerInOKC - Anxious is the correct terminology to describe how I feel... I have very limited faith in this O.S. GGT10... However, I didn't use glow engines for so many year now and I do not want to get back to them, also they will probably be more suitable for this aeroplane.
Eran
Old 05-03-2018, 01:20 AM
  #125
erans
The O.S. GGT10 prevented me from enjoying the Kwik Fli III. To date I have only 6 flights on it.
A friend offered me a used O.S. 55AX for free and I decided to give it a go as I could not see a 10cc Petrol solution becoming available to me anytime soon.
The good news is that the 55AX has identical dimensions to the GGT10 including mounting holes. It is also lighter by ~55g.
I re-fitted the fuel tank with silicone tubes and re balanced the aeroplane, removing 20g from the tail to achieve the same CG.
First opportunity to fly this new combination should be Sunday week (unfortunately our airfield host a competition in the coming Sunday). I will keep this thread posted once I flew it.
Cheers,
Eran
