Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Scratch Built Kwik Fli III
Old 10-18-2017, 10:01 PM
erans
Sheeting the top of the wing now, starting with the D-Box.
I decided to attach the wing to the fuselage using dowels and wing screw in lieu of the rubber bands, which will require some plywood reinforcement at the TE centre section where the holes for the wing screws will be drilled.
Eran
Name:	2017_01_09 01 Kwik Fli 3 Top Right Wing Sheeting Glue Stage 1.JPG
ID:	2241614   Click image for larger version
Name:	2017_01_10 01 Kwik Fli 3 Top Right Wing Sheeting Glue Stage 2.JPG
ID:	2241615   Click image for larger version
Name:	2017_01_10 02 Kwik Fli 3 Top Left Wing Sheeting Stage 1.JPG
ID:	2241616   Click image for larger version
Name:	2017_01_10 03 Kwik Fli 3 Top Left Wing Sheeting Stage 1.JPG
ID:	2241617   Click image for larger version
Name:	2017_01_11 01 Kwik Fli 3 Top Left Wing Sheeting Stage 2.JPG
ID:	2241618   Click image for larger version
Name:	2017_01_11 02 Kwik Fli 3 Top Left Wing Sheeting complete.JPG
ID:	2241619   Click image for larger version
Name:	2017_01_11 03 Kwik Fli 3 Wings Sheeting.JPG
ID:	2241620   Click image for larger version
Name:	2017_01_11 04 Kwik Fli 3 Wing.JPG
Old 10-19-2017, 05:41 AM
FlyerInOKC
FlyerInOKC's Avatar
Well dowels and bolts don't sag with age like rubberbands!
Old 10-21-2017, 01:44 AM
erans
FlyerInOKC - I didn't think that rubber bands and Petrol residue will be a good idea...
My friend David kindly routed for me the channel in the landing gear bracket.
It is now glued into place, which will allow me to complete the sheeting of the bottom of the wing.
Eran
Name:	2017_01_11 05 Kwik Fli 3 LG Wood from David.JPG
ID:	2241779   Click image for larger version
Name:	2017_01_11 06 Kwik Fli 3 LG.JPG
ID:	2241780   Click image for larger version
Name:	2017_01_11 07 Kwik Fli 3 LG.JPG
ID:	2241781   Click image for larger version
Name:	2017_01_12 01 Kwik Fli 3 LG.JPG
ID:	2241782   Click image for larger version
Name:	2017_01_12 02 Kwik Fli 3 LG.JPG
ID:	2241783   Click image for larger version
Name:	2017_01_12 03 Kwik Fli 3 LG.JPG
ID:	2241784   Click image for larger version
Name:	2017_01_13 01 Kwik Fli 3 LG.JPG
ID:	2241785   Click image for larger version
Name:	2017_01_13 02 Kwik Fli 3 LG.JPG
Name:	2017_01_14 01 Kwik Fli 3 LG.JPG
Old 10-21-2017, 07:04 PM
FlyerInOKC
FlyerInOKC's Avatar
That should work!
Old 10-23-2017, 12:35 AM
erans
FlyerInOKC - It better works... Fixing LG mounts is one of my hated jobs. This one designed correctly and should easily be sufficient.
I did some more sheeting over the LG mounts, and sheeted between the ribs where I will have the ailerons servos.
Eran.
Name:	2017_01_14 02 Kwik Fli 3 Sheeting.JPG
ID:	2242168   Click image for larger version
Name:	2017_01_14 03 Kwik Fli 3 Sheeting.JPG
ID:	2242169   Click image for larger version
Name:	2017_01_14 04 Kwik Fli 3 Sheeting.JPG
ID:	2242170   Click image for larger version
Name:	2017_01_14 05 Kwik Fli 3 Sheeting.JPG
ID:	2242171   Click image for larger version
Name:	2017_01_14 06 Kwik Fli 3 Sheeting LG Slots.JPG
ID:	2242172   Click image for larger version
Name:	2017_01_14 07 Kwik Fli 3 Sheeting LG Slots.JPG
ID:	2242173   Click image for larger version
Name:	2017_01_14 08 Kwik Fli 3 Sheeting Servo hole.JPG
Old 10-25-2017, 11:37 PM
  #31
erans
The deviation from the original design includes the installation of servo per aileron in the wing.
As the bottom section is made of sheeting, all future maintenance (if ever required) will be done from the top of the wing.
This will require to cut a hole in the Monokote covering and remove the servo mount, which will allow access to the servo screws.
I made a mistake, cutting of hole for the servo horn in the wrong place (D'oh!), which has been rectified.
Eran
Name:	2017_01_14 10 Kwik Fli 3 Servo Mount.JPG
ID:	2242519   Click image for larger version
Name:	2017_01_14 11 Kwik Fli 3 Servo Mount.JPG
ID:	2242520   Click image for larger version
Name:	2017_01_14 12 Kwik Fli 3 Servo Mount.JPG
ID:	2242521   Click image for larger version
Name:	2017_01_14 14 Kwik Fli 3 Servo Mount.JPG
ID:	2242522   Click image for larger version
Name:	2017_01_15 01 Kwik Fli 3 Servo fit.JPG
ID:	2242523   Click image for larger version
Name:	2017_01_15 02 Kwik Fli 3 Servo fit.JPG
ID:	2242524   Click image for larger version
Name:	2017_01_15 03 Kwik Fli 3 Servo fit.JPG
ID:	2242525   Click image for larger version
Name:	2017_01_15 06 Kwik Fli 3 Servo fit.JPG
Name:	2017_01_15 07 Kwik Fli 3 Servo fit.JPG
Old 10-27-2017, 09:49 PM
  #32
erans
I got the draw wire for the servos in place, and on with some more sheeting... Top section of TE.
Eran
Name:	2017_01_15 08 Kwik Fli 3 Servo Wire String.JPG
ID:	2242669   Click image for larger version
Name:	2017_01_21 01 Kwik Fli 3 Wing Sheeting.JPG
ID:	2242670   Click image for larger version
Name:	2017_01_21 02 Kwik Fli 3 Wing Sheeting.JPG
ID:	2242671   Click image for larger version
Name:	2017_01_21 03 Kwik Fli 3 Wing Sheeting.JPG
ID:	2242672   Click image for larger version
Name:	2017_01_21 04 Kwik Fli 3 Wing Sheeting.JPG
ID:	2242673   Click image for larger version
Name:	2017_01_23 01 Kwik Fli 3 Wing Sheeting.JPG
ID:	2242674   Click image for larger version
Name:	2017_01_23 02 Kwik Fli 3 Wing Sheeting.JPG
ID:	2242675   Click image for larger version
Name:	2017_01_23 03 Kwik Fli 3 Wing Sheeting.JPG
Name:	2017_01_24 01 Kwik Fli 3 Wing Sheeting.JPG
ID:	2242677   Click image for larger version
Name:	2017_01_24 02 Kwik Fli 3 Wing Sheeting.JPG
Old 10-30-2017, 09:51 AM
  #33
FlyerInOKC
FlyerInOKC's Avatar
I was out of town all last week it looks like you are still making good progress.
Old 10-31-2017, 06:42 AM
  #34
erans
Sheeting is finally done, and servo extension leads are in place. It looks quite good now. Very solid wing.
Eran
Name:	2017_01_24 03 Kwik Fli 3 Servo Extentions.JPG
ID:	2243153   Click image for larger version
Name:	2017_01_24 04 Kwik Fli 3 Wing Sheeting.JPG
ID:	2243154   Click image for larger version
Name:	2017_01_24 05 Kwik Fli 3 Wing Sheeting.JPG
ID:	2243155   Click image for larger version
Name:	2017_01_24 06 Kwik Fli 3 Wing Sheeting.JPG
ID:	2243156   Click image for larger version
Name:	2017_01_24 07 Kwik Fli 3 Wing Sheeting.JPG
Old 10-31-2017, 09:00 AM
  #35
FlyerInOKC
FlyerInOKC's Avatar
Wing looks great!
Old 11-01-2017, 06:48 AM
  #36
erans
Thank you FlyerInOKC.
The wing was tidied up after the last rib, and solid balsa blocks were glued to be shaped as wing tips.
Eran
Name:	2017_01_24 08 Kwik Fli 3 Wing Tips.JPG
ID:	2243243   Click image for larger version
Name:	2017_01_24 09 Kwik Fli 3 Wing Tips.JPG
ID:	2243244   Click image for larger version
Name:	2017_01_24 10 Kwik Fli 3 Wing Tips.JPG
ID:	2243245   Click image for larger version
Name:	2017_01_24 11 Kwik Fli 3 Wing Tips.JPG
ID:	2243246   Click image for larger version
Name:	2017_01_24 12 Kwik Fli 3 Wing Tips.JPG
ID:	2243247   Click image for larger version
Name:	2017_01_25 01 Kwik Fli 3 Wing Tips.JPG
ID:	2243248   Click image for larger version
Name:	2017_01_25 02 Kwik Fli 3 Wing Tips.JPG
Old 11-01-2017, 06:54 AM
  #37
FlyerInOKC
FlyerInOKC's Avatar
Eran, do initially shape your tip blocks before gluing them on and then fine tune the shape after gluing or do you glue the block in place and then shape?
Mike
Old 11-01-2017, 11:35 PM
  #38
erans
FlyerInOKC - I prefer to sand into shape when I have the corresponding structure attached, but, I don't think there is right or wrong doing it either way.
And, talking about sanding, I got both the wing tips and leading edges done.
Eran
Name:	2017_01_30 01 Kwik Fli 3 Wing Tips.JPG
ID:	2243326   Click image for larger version
Name:	2017_01_30 02 Kwik Fli 3 Wing Tips.JPG
ID:	2243327   Click image for larger version
Name:	2017_01_30 03 Kwik Fli 3 Wing Tips.JPG
ID:	2243328   Click image for larger version
Name:	2017_01_31 01 Kwik Fli 3 Wing Tip.JPG
ID:	2243329   Click image for larger version
Name:	2017_01_31 02 Kwik Fli 3 LE Sanded.JPG
ID:	2243330   Click image for larger version
Name:	2017_01_31 03 Kwik Fli 3 LE Sanded.JPG
Old 11-02-2017, 11:39 AM
  #39
FlyerInOKC
FlyerInOKC's Avatar
They look great!
Old 11-03-2017, 12:25 AM
  #40
erans
A bit more work done. Cutting the ailerons, filling the gaps in the secondary spar and the aileron "LE", then repeating for the other side.
Eran
Name:	2017_01_31 04 Kwik Fli 3 Ail.JPG
ID:	2243390   Click image for larger version
Name:	2017_01_31 05 Kwik Fli 3 Ail.JPG
ID:	2243391   Click image for larger version
Name:	2017_01_31 06 Kwik Fli 3 Ail.JPG
ID:	2243392   Click image for larger version
Name:	2017_01_31 07 Kwik Fli 3 Ail.JPG
ID:	2243393   Click image for larger version
Name:	2017_01_31 08 Kwik Fli 3 Ail.JPG
ID:	2243394   Click image for larger version
Name:	2017_01_31 09 Kwik Fli 3 Ail.JPG
ID:	2243395   Click image for larger version
Name:	2017_01_31 10 Kwik Fli 3 Ail.JPG
ID:	2243396   Click image for larger version
Name:	2017_01_31 11 Kwik Fli 3 Ail.JPG
Name:	2017_02_03 01 Kwik Fli 3 Ail.JPG
ID:	2243398   Click image for larger version
Name:	2017_02_03 02 Kwik Fli 3 Ail.JPG
ID:	2243399   Click image for larger version
Name:	2017_02_03 03 Kwik Fli 3 Ail.JPG
ID:	2243400   Click image for larger version
Name:	2017_02_03 04 Kwik Fli 3 Ail.JPG
Old 11-03-2017, 05:12 AM
  #41
FlyerInOKC
FlyerInOKC's Avatar
It's going to be one nice bird and with those ailerons she'll be very responsive.
Old 11-04-2017, 12:15 AM
  #42
erans
FlyerInOKC - I hope it will be responsive, it was a pattern aeroplane after all...
Final touches to the wing before covering, cup strips glued into place and filler applied.
This must be up there with the best wings I ever built.
Eran
Name:	2017_02_05 01 Kwik Fli 3 Cup Strips.JPG
ID:	2243459   Click image for larger version
Name:	2017_02_05 02 Kwik Fli 3 Cup Strips.JPG
ID:	2243460   Click image for larger version
Name:	2017_02_05 03 Kwik Fli 3 Cup Strips.JPG
ID:	2243461   Click image for larger version
Name:	2017_02_05 04 Kwik Fli 3 Wing Complete.JPG
ID:	2243462   Click image for larger version
Name:	2017_02_05 05 Kwik Fli 3 Wing Complete.JPG
ID:	2243463   Click image for larger version
Name:	2017_02_05 06 Kwik Fli 3 Wing Complete.JPG
ID:	2243464   Click image for larger version
Name:	2017_02_21 01 Kwik Fli 3 Wing Filling .JPG
ID:	2243465   Click image for larger version
Name:	2017_02_21 02 Kwik Fli 3 Wing Filling .JPG
Name:	2017_02_21 03 Kwik Fli 3 Wing Filling .JPG
ID:	2243467   Click image for larger version
Name:	2017_02_21 04 Kwik Fli 3 Wing Filling .JPG
Old 11-06-2017, 04:19 AM
  #43
erans
One of my favorite activities when scratch building is covering, especially when using Monokote.
Therefore, to have a break from construction the next stage is covering the wing in its basic orange, before making a start on the fuselage.
I started with covering the areas that are not part of the main covering exercise.
The plans have no hinging information and I think it is reasonable to assume that no hinging is required. It should be plenty strong to use the covering as a hinge. However, I decided to install hinges on the narrow section (top of aileron) and hide it under the covering (just in case...).
Eran
Name:	2017_02_25 01 Kwik Fli 3 Ail Pre Covering.JPG
ID:	2243832   Click image for larger version
Name:	2017_02_25 02 Kwik Fli 3 Ail Pre Covering.JPG
ID:	2243833   Click image for larger version
Name:	2017_02_25 03 Kwik Fli 3 Ail Pre Covering.JPG
ID:	2243834   Click image for larger version
Name:	2017_02_25 04 Kwik Fli 3 Ail Pre Covering.JPG
ID:	2243835   Click image for larger version
Name:	2017_02_25 05 Kwik Fli 3 Ail Pre Covering.JPG
ID:	2243836   Click image for larger version
Name:	2017_02_25 06 Kwik Fli 3 Ail Pre Hinging.JPG
ID:	2243837   Click image for larger version
Name:	2017_02_25 07 Kwik Fli 3 Ail Hinging.JPG
ID:	2243838   Click image for larger version
Name:	2017_02_25 08 Kwik Fli 3 Ail Hinging.JPG
Name:	2017_02_25 09 Kwik Fli 3 Ail Hinging.JPG
ID:	2243840   Click image for larger version
Name:	2017_02_25 10 Kwik Fli 3 Ail Hinging.JPG
ID:	2243841   Click image for larger version
Name:	2017_02_25 11 Kwik Fli 3 Ail Hinging.JPG
ID:	2243842   Click image for larger version
Name:	2017_02_25 12 Kwik Fli 3 Ail Hinging.JPG
ID:	2243843   Click image for larger version
Name:	2017_02_25 13 Kwik Fli 3 Ail Hinging.JPG
ID:	2243844   Click image for larger version
Name:	2017_02_25 14 Kwik Fli 3 Ail Hinging.JPG
Old 11-06-2017, 06:38 AM
  #44
FlyerInOKC
FlyerInOKC's Avatar
Consider the speed and stress of going thru the pattern I don't think I would want to rely on just the covering for hinging either.
Old 11-07-2017, 09:30 PM
  #45
erans
FlyerInOKC - I genuinely do not think that the forces on the ailerons for this model will be an issue for "Monokote hinge", however, it is a no issue anymore as DuBro hinges are in place : )
The covering of the bottom of the wing is done and the servos installed. Covering is like a therapy...
I need some more Monokote, so I will put the wing away and start working on the horizontal stabilizer.
Eran
Name:	2017_02_27 01 Kwik Fli 3 Wing Covering.JPG
ID:	2244051   Click image for larger version
Name:	2017_02_27 02 Kwik Fli 3 Wing Covering.JPG
ID:	2244052   Click image for larger version
Name:	2017_02_27 03 Kwik Fli 3 Wing Covering.JPG
ID:	2244053   Click image for larger version
Name:	2017_02_27 04 Kwik Fli 3 Wing Covering.JPG
ID:	2244054   Click image for larger version
Name:	2017_02_27 05 Kwik Fli 3 Wing Covering.JPG
ID:	2244055   Click image for larger version
Name:	2017_02_27 06 Kwik Fli 3 Ail Servo.JPG
ID:	2244056   Click image for larger version
Name:	2017_02_27 07 Kwik Fli 3 Ail Servo.JPG
ID:	2244057   Click image for larger version
Name:	2017_02_27 08 Kwik Fli 3 Ail Servo.JPG
Name:	2017_02_27 09 Kwik Fli 3 Ail Servo.JPG
Old 11-08-2017, 05:53 AM
  #46
FlyerInOKC
FlyerInOKC's Avatar
Looking good Eran! Man, that is a lot of orange! What trim color will you use?
Old 11-08-2017, 06:08 AM
  #47
erans
FlyerInOKC - I will be duplication the colour scheme used by Phil Kraft as in the first photo I posted in black and white (re posted here), and the only colour photo of that aeroplane that I found (the further away aeroplane in the "Model Plane Building..." image). I also found the third image posted here somewhere on the Internet...
Eran
Name:	Kwik Fli III.jpg
ID:	2244094   Click image for larger version
Name:	Kwik Fli III two colour schemes.png
ID:	2244095   Click image for larger version
Old 11-08-2017, 06:41 AM
  #48
FlyerInOKC
FlyerInOKC's Avatar
Cool! I have a partially built CG Tiger project that was given to me I was going to do the wing and the back 3/4 of the fuselage in orange and the wing trim and front of the fuselage in white. Here is the side art I had made. The project just screams for a Tiger..
Old 11-12-2017, 02:55 AM
  #49
erans
FlyerInOKC - Great graphics. My daughter says "cute!"
I got on with the horizontal stabilizer. It went together quickly.
Eran
Name:	2017_02_28 01 Kwik Fli 3 Horiz Stab.JPG
ID:	2244576   Click image for larger version
Name:	2017_02_28 02 Kwik Fli 3 Horiz Stab.JPG
ID:	2244577   Click image for larger version
Name:	2017_02_28 06 Kwik Fli 3 Horiz Stab.JPG
ID:	2244578   Click image for larger version
Name:	2017_02_28 07 Kwik Fli 3 Horiz Stab.JPG
ID:	2244579   Click image for larger version
Name:	2017_02_28 12 Kwik Fli 3 Horiz Stab.JPG
ID:	2244580   Click image for larger version
Name:	2017_02_28 13 Kwik Fli 3 Horiz Stab.JPG
ID:	2244581   Click image for larger version
Name:	2017_02_28 14 Kwik Fli 3 Horiz Stab.JPG
ID:	2244582   Click image for larger version
Name:	2017_02_28 15 Kwik Fli 3 Horiz Stab.JPG
Old 11-13-2017, 06:53 AM
  #50
FlyerInOKC
FlyerInOKC's Avatar
Calvin and Hobbs was always a favorite comic of mine. It seemed fitting with the number of times Hobbs pounced on Calvin when he came home from school to but him on my GC Tiger.
