E50 fit out.
E50 fit out.
This is another one of Edelwiess' tanks.i bought as a shell and intended servo recoil and elevation, led flash, hidden battle system, tcb, benedini, beefy speaker box, low ratio gears and possibly a tensioner.
Tonight I added the servo recoil and elevation. I rebuilt the tamiya recoil with a servo, which necessitated some minor surgery but it just fits. Elevations quick and dirty, the barrel is weighted to point down so I used a micro servo arm pushes it back up, because there's no linkage it's safe from damage should the barrel take a
knock.
I'm testing the recoil using a sirveo (hence the reversed action) and the elevation with a pot on the radio so it's not a smooth as it should be.
https://youtu.be/1OzLPRnjpgI
Sent from my SM-G950F using Tapatalk
knock.
Like that E-50!!!!
Hey folks, a little progress on the e50, I've now got all the turret functions boxed off so, servo recoil and elevation, vampire hidden receiver, hidden emitter in the turret front and LED flash. I've also built up the speaker box and fitted that. All I need to do now is get the radio so I can use the sbus tk24 in the short term (hopefully upgrade to tk60 in the future), need to fit the head and convoy lights. Long term I'm going to add a henntec adjuster and the propulsion dynamics gearbox.
Sent from my iPhone using Tapatalk
Is this Ludwigs E-50 kit? Nice build.
