Reload this Page >
TopRc Voyager build
TopRc Voyager build
Old 02-19-2020, 04:34 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Default TopRc Voyager build
So I’m starting the big voyager building so I’m planning to post some build pictures, maybe someone will like to watch.
Old 02-19-2020, 05:55 PM
sysiek
My Feedback: (176)
sysiek's Avatar
So all the horn pockets needed to be enlarged and cleaned they smaller and shorter than the horns,very easily but still time consuming,so today all the horns are glued and the rudder hinges,next the servos.
Old 02-20-2020, 08:54 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Ok so wing servos today, so all the hardware are supplied are up to the number all is included and they fit perfectly just need to drilled some holes into the servo plates, so I’m using the industrial strength two faced tape to help me hold the servos in place when drilling and installing the screws plus this will make the servos to be more secure and stay there with more holding power.
Old 02-23-2020, 07:41 PM
Dapreacherman48
Same control horn pocket issue on the odyssey.
sand the sides of the horn that goes into the pockets.
Old 02-23-2020, 08:09 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Usually I’m using dremell to make the glued aides sanded so they could bite with the glue.
Old 02-23-2020, 08:13 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Today I was working on the elevators servos and I wish that the company did the cutting for the servo arms this will cut the build time and all the hassle with measurements where those cuts should go, but so far the building goes better than some skymaster stuff that I have before.
Jason_H (12-05-2020)
Old 02-24-2020, 10:30 PM
vquick
My Feedback: (71)
vquick's Avatar
They don't do that cause depend on servo you plan to use
Old 02-25-2020, 06:19 AM
sysiek
My Feedback: (176)
sysiek's Avatar
That’s possible, so the elevators servos are installed.
Old 02-25-2020, 07:32 AM
camss69
My Feedback: (46)
camss69's Avatar
Does the plane have a flat finish?
Old 02-25-2020, 11:14 AM
sysiek
My Feedback: (176)
sysiek's Avatar
Yes flat clear coat, very nice finish, will post more pictures when the fuselage assembly
Old 03-01-2020, 06:38 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Ok so this weekend, the fuselage is all together, the aluminum alignment tubes are glued to the rear section,and all the servos pushrods installed, the note please use the 3mm tap to re do the plastic ball connectors the almost impossible to do with just the pushrod, and use 3mm drill for all the glued horns maybe before glued them to the surfaces, the jets is actually very cool and is very compact the jet could be transported in two main elements back and bigger front with turbine and all the stuff to make it rtf the back will be just the rear fuselage with pipe and 3 servos cables for elevators and rudder, I’m planning to use the electrodynamics plug for 3 servos to make the separation much easier.
Old 03-01-2020, 06:43 PM
sysiek
My Feedback: (176)
sysiek's Avatar
And this is what you need to glue to the rudder and elevators
Old 03-01-2020, 07:18 PM
vquick
My Feedback: (71)
vquick's Avatar
If you interested we make a kevlar tank who fit with some small work
Old 03-01-2020, 07:33 PM
sysiek
My Feedback: (176)
sysiek's Avatar
This one is actually very cool, how much for the tank? Thanks again
Old 03-01-2020, 07:37 PM
vquick
My Feedback: (71)
vquick's Avatar
300.00 shipped with high flow fittings and clunk
Old 03-02-2020, 10:59 PM
vquick
My Feedback: (71)
vquick's Avatar
Correction on Fuel tank price will be $265.00 shipped
Old 03-02-2020, 11:25 PM
sysiek
My Feedback: (176)
sysiek's Avatar
I think I might need one for my next one, when building it as a my jet , this one is sold to a new owner, I’m waiting for the military color.
Old 03-03-2020, 05:11 AM
vquick
My Feedback: (71)
vquick's Avatar
The new one comes with fiberglass tank and smoke tank
Old 03-03-2020, 05:14 AM
vquick
My Feedback: (71)
vquick's Avatar
I build one back in December
https://www.facebook.com/groups/3394...0231575860859/
Old 03-03-2020, 07:45 AM
sysiek
My Feedback: (176)
sysiek's Avatar
One problem I don’t have a f-book, maybe you could post all the pictures right hire, this will be useful thanks again
Old 03-05-2020, 08:41 PM
sysiek
My Feedback: (176)
sysiek's Avatar
So today some rear servo cables, I’m using high temperature resistant tube to cover the cables from possible heat from pipe if something happens at least this will help to have some extra time to maybe have the jet landing safely, maybe because I have seen some jets goes down because some of the cables got in contact with the pipe and the rest what happens you know,
Old 03-06-2020, 06:53 AM
dmac
My Feedback: (18)
One small recommendation. Get yourself some step drills and then you can drill nice neat holes with no tear out on composite materials.
Old 03-06-2020, 07:21 AM
sysiek
My Feedback: (176)
sysiek's Avatar
This is how they did the holes not me , and I have some off those drills maybe I’m going to fix something or just use some send paper and paint to fix the openings
bodywerks (03-09-2020)
Old 03-16-2020, 05:02 PM
David Jackson
My Feedback: (15)
Any updates on the Voyager?
Old 03-16-2020, 05:55 PM
sysiek
My Feedback: (176)
sysiek's Avatar
Waiting for some fuel lines and some other stuff will go back to the jet soon, thanks for asking
