Reload this Page >
CARF Mephisto Build thread
Old 04-28-2018, 04:05 AM
  #101
Dave Wilshere
Chet
Ah, CARF supply that small rectangular tank as a bubble trap that you make yourself. So either make it as a bubble trap or use a commercial unit.
Smoke tank with a felt clunk does not need a bubble trap with the good tank shape and felt pick up
Dave
Old 04-28-2018, 04:20 AM
  #102
GULDUKAT
Dave,
Thank you for the clarification. I think I got the lineup now.
Now as far as the fuel lines or concerned you are recommending to stick to the for 4MM supplied lines. On my other big jets that are in series I use 6MM fuel line or a 3/16 tygon. I also use high flow set up inside my tanks as well.
Do you not recommend I swap that out for 6mm or 3/16 tygon in the mephisto since it is in series?
I do a lot of aerobatics and a lot of inverted flying and I've had a few flame out because off not having the proper fuel lines and auto restart saving me in the past.
I want to make sure that this parallel set up is quite different than all my series set up.
I have a BF300 as the power plant.
Chet
Old 04-28-2018, 04:50 AM
  #103
Dave Wilshere
I think BF use 4mm o/d std tube from the pump to the turbine. The tube supplied with the CARF kit is 6mm o/d and 4mm i/D this is from the tanks to the hopper. Inside the tanks I would use 5/32 i/d Tygon tube.
Other than this you should be fine, with a 300 the Mephisto will do normal aerobatics with low throttle, full power and pump supply is only used if you hover.
You should modify the ducting for the 300 as its a large turbine that blocks the full byepass.
Dave
Old 04-28-2018, 04:56 AM
  #104
GULDUKAT
Dave
Do you have any photographs or additional information about the modifications required to accommodate the BF300?
Chet
Old 04-28-2018, 05:46 AM
  #105
Dave Wilshere
One of my customers is just finishing the modifications, will photograph when I see him.
Old 04-28-2018, 07:26 AM
  #106
JTFDEZ
Hi fellows, can anyone please post some pictures on how install the gear door servos in the nws?
thanks
Old 04-28-2018, 09:52 AM
  #107
Dave Wilshere
Several options available,wing servos or like this.
  #108
Andrew Bird
Andrew Bird's Avatar
I'm away with work so can't take any photo's but there are a few options.
I think CARF intended people to use side mount servo's which can be mounted to a wooden plate (supplied with the kit) to the composite surface over the top of the doors. I used the wooden plate and glued it to the side wall next to the door hinge and screwed the servo to that (obviously one each side). It sounds more complicated than it was - it was a pretty straight forward set up.
Old 04-28-2018, 09:54 AM
  #109
Andrew Bird
Ah - Dave beat me to it! On the pair that I've built I mounted the servos so the sidewall which also works
Old 04-28-2018, 11:05 AM
  #110
ZivBit
ZivBit's Avatar
Old 04-30-2018, 12:59 PM
  #111
JTFDEZ
Thanks to Andrew and Dave.... "an image says more than a thousand words"
May I bother you with some pictures of vectorial servo installation ???
thanks again
Old 04-30-2018, 11:09 PM
  #112
Dave Wilshere
There is plenty of space, pitch vector servo just needs to miss the chine opening.
Dave
Old 05-01-2018, 12:45 PM
  #113
Andrew Bird
One without the pipe in if it helps (and wires everywhere).
Old 05-06-2018, 03:55 PM
  #114
vquick
My Feedback: (71)
vquick's Avatar
Old 05-21-2018, 12:08 AM
  #115
Dave Wilshere
Few pictures from weekend with Tim Jenkinson's Mephisto Mercury Powebox, JR 28x BF-300
Old 05-21-2018, 05:04 AM
  #116
RC_MAN
Do you have to flip the airplane over to attach the wings? I hope not.
Old 05-21-2018, 05:39 AM
  #117
Andrew Bird
Nope!
Old 05-22-2018, 11:57 AM
  #118
Andrew Bird
Mine is pretty close to being finished (waiting on the turbine still) but thought I'd snap some pics while working on the radio set up and starting on building the next one for a mate of mine.
Old 06-01-2018, 01:58 PM
  #119
Dave Wilshere
video containing two Mephisto models, mine and friend Tim Jenkinson, BF 300, Powerbox Mercury, JR 28x
Old 06-04-2018, 05:44 AM
  #120
Dave Wilshere
Took my Mephisto to Scotland over the weekend to use as a demo model between Helicopter competition rounds.
Pics from Billy-thanks
guess my lap top has other pictures with same name!
Old 06-04-2018, 06:27 AM
  #121
skymaster68
Mine is ready, but have to wait a few month for KingTech to have the 310 available again
Old 06-04-2018, 11:57 PM
  #122
GULDUKAT
Same here. Any ideas on release date? Also any chance you are flying on Futaba?
Old 06-05-2018, 07:26 PM
  #123
skymaster68
just heard from Kt not before October 😩 dont’t think I can wait that long, I wonder what if i go with a 260 insted, will it be enough 🤔 i ‘ve seen some guys making a lot of 3D staff with a 250 ....
Yes I’m flying Futaba
Old 06-05-2018, 09:12 PM
  #124
Dave Wilshere
It 3D’s fine with a 220, big knife edge loops, it just won’t allow you to hover until the last minute of the flight. Flying weight will have an effect, it’s a big model, so even wiring type and routing can add a few hundred grams. If you watch Tim’s video that is 3-Ding with 250N
Old 06-06-2018, 12:29 AM
  #125
GULDUKAT
It should do most things and maybe even hover in the last few mins. I got a K260 that I bench tested yesterday. Wow - just like the K210 - fast spool up - fired right up. Auto restart works just fine.
I plan to fly it in the Mephisto soon and then replace it with the revised K310 when it is out.
As far as your Futaba setup - are you using a single receiver or dual and are you using a power distribution box?
Chet
