Reload this Page >
It's coming! Skymaster F-18 1/6 on 2016
Old 03-24-2017, 03:05 AM
  #176
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by FenderBean
no problem, it's such a nice looking gear already just trying to make it great!
I suffer from being a bit of a perfectionist, and this model is on the buy list.
Kieth I doubt the gear will swing without hitting the doors if the tires get changed. You might be able to redo the outboard rear gear door hinges but they way they come stock the tires just clear them when moving.
The tires are the correct size but they are the incorrect shape with the sidewalls being to small. IMO this is needed to get the gear to clear the doors on the way up.
The leading edge fences are not even close to the correct size for scale. I gave Anton mine at FLjets since I didnt mount them yet so he can copy them. I took measurements from the full scale then trimmed down the stock ones ALLOT to get them right. So hopefully new kits will ship with the correct size.
Old 03-24-2017, 08:38 AM
  #177
FenderBean
FenderBean's Avatar
Gun based on the chart on previous page the wheels are not correct, the tire on the E/F is 32 inches diameter and most importantly is width. Like We said before the shape of the tire is the problem which is making it look smaller. It's seems like a small thing but when scaled smaller a couple mm can change the look significantly. I reference the E/F numbers because they use the same gear for the C/D just changed the scale of the jet. It also sounds like the door scale or just the way the gear closing Is an issue with a correct tire. The hub is way past the side walls and the picture of Likai measuring the real gear on the website shows the more square shape tire with a hub that is flush with the side walls. Anyway it's just a model, I brought this up since I like the model and would like to build. I don't expect anything will change but wanted to try It's still a nice model.
Old 03-24-2017, 09:14 AM
  #178
TJP
My Feedback: (24)
Anyone know what engine setup that Jim Martin's F-18f had??
Old 03-24-2017, 09:26 AM
  #179
gunradd
My Feedback: (9)
gunradd's Avatar
He is now running twin K210s in his.
If I was doing one all over again I would go with a single K210 or K260 when it comes out and if twins then twin K120s and I would not go with tail mounted engines. I did not like that set up and the mid mounted setup looks better to me.
Mine was set up heavy with animitronic pilots (6 servos and controller) moving tail hook and so on. It still weighed in at 57 lbs with twin K180s. You could get the weight down easy to closer to 50lbs with a K210 setup by the time you loose the extra ECU battery, UAT, Wiring ECU, second engine, and nose weight.
Old 03-24-2017, 10:05 AM
  #180
ravill
ravill's Avatar
That was a sweeeeettt take off with Jim's supa hornee!!
Old 03-28-2017, 11:27 AM
  #181
EDFJim
https://youtu.be/y7ewsWo-mUI
Here is a flight with the thrust vectoring getting tested.
Old 03-28-2017, 01:16 PM
  #182
zdsh13
Few questions for Anton:
- Is there plans to test the C/D rear engine mount version on one engine?
- Can the factory confirm the engine thrust angles on the rear mount version are correct as mounted in the airframe?
- I have a rear engine mount airframe, do you have a retrofit kit mount for twin mid mount or single turbine mount if I buy the pipes?
Old 03-28-2017, 01:21 PM
  #183
FenderBean
FenderBean's Avatar
Seems like it's going to have a very limited window on thrust V maneuvers. Seems to make the high alpha easier.
Old 03-29-2017, 06:45 AM
  #184
pilot tw
Hi,
We didn’t test the single engine installation at tail,
You need to add washer and adjust angle at your side.
You can buy another thrust pipe,and convert to single engine in the middle of fuselage,
Old 03-29-2017, 07:24 AM
  #185
FenderBean
FenderBean's Avatar
Originally Posted by pilot tw
Hi,
Any plans to test the single engine flight?
Old 03-29-2017, 07:28 AM
  #186
zdsh13
Thx for your quick reply Anton, I am looking forward to receiving my new F-18C as it looks like a wonderful project but there are still some concerns.
I read the assembly manual and it states nothing about the recommended engine thrust line. My thoughts are you would want a few degree toe in to offset the gyroscopic effect of a single engine. I agree that on our end we can shim the engines to match but the important thing here is what does the factory reccomend for proper engine thrust line in degrees?
Also will you initiate a series of test flights to check single engine operation, ideally take off on 2 engines and shut one down and test flying stability.
Skymaster has developed a beautiful airframe and has decided to implement rear engine installation, I would hope that the company with the great reputation it has would be willing to perform the due diligence needed to ensure the model is stable under this condition before distribution of the model.
This is a high end model with large dollar investment, I would think your customers would appreciate this testing and further updating the manual of the recommended findings.
Thx
Hi,
Old 03-29-2017, 12:35 PM
  #187
gunradd
My Feedback: (9)
gunradd's Avatar
Thx
Well said. I wish testing was done then mine would still be here. from what I am hearing they plan on doing testing now.
Old 03-29-2017, 06:10 PM
  #188
pilot tw
Congratulations to Michel's F-18f 1/6 maiden ,
Hi Anton, today I did the maiden of the new F-18F 1:6.
I must say this jet is simply amazing, very good prescience in the air and incredibly stable to fly.
For power I use two Jet Central Cheetah turbines which produce enough power to have huge verticals.
Landings where very easy and stable also.
This is an absolute winner Anton. Congrats on a great jet.
Here is a video of the maiden day.
https://youtu.be/oo2hId9ULkk
Best regards,
Michel Durand
JETSRC.com
ID:	2207609   Click image for larger version
ID:	2207610   Click image for larger version
ID:	2207611   Click image for larger version
ID:	2207612   Click image for larger version
ID:	2207613   Click image for larger version
ID:	2207614   Click image for larger version
ID:	2207615   Click image for larger version
Old 03-29-2017, 06:46 PM
  #189
pilot tw
https://www.youtube.com/watch?v=oo2hId9ULkk&feature=youtu.be
Old 03-30-2017, 04:46 AM
  #190
Craig B.
Vey nice flying as usual Michel! Great landing. Did you have centre-mounted engines with pipes?
Old 03-30-2017, 08:12 AM
  #191
JetsRC
JetsRC's Avatar
Hi Craig, thanks!!!! Glad you liked the video Anton posted of my flight. I must trulls say I am really impressed on this F-18F, I have had many F-18s of different brand and sizes and this is definitely the best one I have ever flown. I can also say it is one ion the nicest jets I have ever flown. I was surprised to see how easy to fly it was. The jet had no bad tendencies at all, if you see at about 50 seconds on the video I do a stall test and the F-18 just drps the nose and recovers very quickly.
Landing where really easy to handle.
I logged 3 amazing flights yesterday on the maiden and all went well.
On my setup, engines are mid mounted with pipes, I am using two Jet Central Cheetahs which give amazing verticals.
Old 03-31-2017, 07:15 AM
  #192
Craig B.
Hi Michel,
thanks for the info. Sounds like the best way to go.
Old 04-07-2017, 08:38 PM
  #193
zdsh13
Kind of disappointed that there is no response to my questions, was hoping Skymaster would stand behind their product....
Thx
Old 04-08-2017, 02:55 PM
  #194
pilot tw
Sorry for the reply late , i just back from my long holiday, i will disscuss with Likai then reply to you in couple days.,
Old 04-08-2017, 06:25 PM
  #195
zdsh13
Thank you Anton, looking forward to your response,
Dave
Old 04-08-2017, 07:35 PM
  #196
marcpamjoce
Best regards,
Michel Durand
JETSRC.com
All you el cheepo tight-wads w/ the string bean nose gear. Please take notice, this is how it should be done. I don't ever want to see another f18 w/ an anorexic nose gear, you understand what i am saying? This fat-ass nose gear looks like it has had a few donuts, pork rinds, and fried chicken. You guys need to be all over this like a fat kid on a cupcake.
Old 04-09-2017, 04:36 AM
  #197
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Can someone please tell me how to place someone on ignore
Old 04-11-2017, 01:43 PM
  #198
why_fly_high
My Feedback: (19)
Click on his name. on the left side there is an ignore option.
Old 04-11-2017, 05:46 PM
  #199
pilot tw
after discussed Likai that we will test fly the one turbine fly the F-18 again soon, I plan fly back Taiwan on end of April , we will see the one turbine fly with the Likai;s designed twin turbines in the tail ,. Thank you for attention .,
Old 04-11-2017, 06:50 PM
  #200
zdsh13
Thank you Anton for your diligence on this, it definitely shows us that Skymaster is behind their products and customers.
