It's coming! Skymaster F-18 1/6 on 2016
#476
I m on futaba, but I imagine if you slow down the flaps and mix the rudders in using the flaps as a master, you might get the result you want without slowing down the control surface response as a whole. That's obviously if you wish to deploy the rudders along with the flaps.
#477
My Feedback: (10)
I am not sure about spectrum, but on futaba, you can create a virtual function, like airbrake. Unlike a normal function (like ailerons, anything), a virtual function does not have it's own servo outputs assigned. You assign a switch orknob to the function just like any normal control.
Set "airbrake" speed as slow as you want.
Now set mixers from "airbrake" as the master to whatever you want to control as the slave.
#480
#482
Cool thanks Bass pilot. Was your cockpit a custom build or do they offer them as stock? Did your cockpit come built and painted?
I went the single option with my C model too. P300
Levi
#484
#486
Shout out to Dirk at Pacific RC Jets.
I got my F-18F in last week. It had shipping damage from bad packing. Dirk was way cool about helping coming up with a fare plan to get it taken care of. Stuff happens, its how its dealt with that makes the difference. BTW Skymaster painted my gear in this egg shell white, not the low gloss white that it should have. Make sure that before you order that you specify before ordering.
#487
My Skymaster F-18, 1:5.75, is now official authorised by CIvil Aviation Authority Switzerland with a max take-off mass of 32kg.
Wing load check was 90kg on each wing. Reto Senn from Swissland
#489
My Feedback: (54)
That truly has to be mentally difficult to let someone put that kind of weight on the wings with wood boards that could scratch the paint. I see the foam in the front under the nose. I’m sure that you have a lot of foam under the tail section. Otherwise it could cause denting, hairline cracks, and other damage to the top surface of the airframe. Just testing and proving that it can take the G’s, could end up totaling the jet.
Congrats!
Congrats!
#490
Has anyone had much flight time on the single turbine version with bifurcated pipe? I know of a few guys in the building stage with the single but none flying.
I ordered mine through Intairco here in Oz about 13 weeks ago so I’m hoping I’ll have it soon. P300 to go in.
#493
Hey Fender. Skymaster John sent me some photos of the single install. Looked like enough room but I haven’t seen one in the flesh. Sounds like I’ll have some dremel work to do hey.
#494
Levi
#495
Given the challenges faced by Fenderbean, does anyone know if Skymaster has address the quality issues Fender highlighted? This is a plane in which I have a lot of interest but not if the quality isn't there. Grateful for any thoughts
Bob
Bob
#498
My Feedback: (9)
From what I have seen they have the same problems they had back when I got mine. Talked to a friend and Kentucky with a 1/5 F16 and he was having issues with the lights. We checked the wire connectors and like mine they never stripped the wires and crimped the connectors around the sheilding.
Matt mine went in because I used the stock angle of the engine mounting rails thinking they must know what they are doing for them to be at those angles. Turns out you must use washers to align the engines to the correct angles for single engine flight. For some reason they won’t build a jig and install them straight at the factory. I’ve seen several now And all had misaligned rails.
#499
#500
Thanks for the feedback and pms'. You've all really confirmed my suspicions that little has changed. No manufacturer is perfect and we all expect to do some work but, for my part, I do expect the fundamental issues to be correct - 'alignment' being as fundamental as it gets.
So - I'll just have to pass which is a shame - I love that plane!
Bob
Bob
