Reload this Page >
It's coming! Skymaster F-18 1/6 on 2016
Old 06-23-2017, 05:53 AM
  #326
IFLYBVM2
My Feedback: (360)
Default Sequence
Originally Posted by gunradd
Yes I used all UP stuff for gear and canopy. Only thing is you will need a separate air valve to unlock the gear.
Hi Gunn-
What did you use to sequence the UP setup ?
Old 06-23-2017, 06:04 AM
  #327
mr_matt
My Feedback: (10)
mr_matt's Avatar
Are the air inlets and fuel tanks the same for single turbine/twin mid turbine/twin tail turbine configurations?
Old 06-23-2017, 02:38 PM
  #328
Basspilot
I second the setup question. How do I sequence the unlocking valve with Up valve?
Old 06-23-2017, 05:04 PM
  #329
gunradd
My Feedback: (9)
gunradd's Avatar
I was out of channels dx18 so I ended up adjusting the servo and throw to the point the servo had to travel allot before it made the gear retract. The unlock valve only needs to actuate a split second before the Mains go up. So the valve was on a Y with the UP valve servo. If I had more channels I would have sequenced it in the transmitter.
For gear down it really does not need the extra valve. Its only needed for gear up. Without it your gear will work perfect on the ground but not work in the air.
Old 06-23-2017, 05:06 PM
  #330
gunradd
My Feedback: (9)
gunradd's Avatar
Also on a side note. I installed an air restrictor inline with the main gear and that allowed the gear to retract fine but gear came up real slow so added the valve.
Old 06-23-2017, 05:13 PM
  #331
pilot tw
we have no exprience with UP valve. we use sequence function of PowerBox Royal SRS.
Old 06-23-2017, 09:50 PM
  #332
Looping31
Looping31's Avatar
Originally Posted by pilot tw
First flight was one Engine take-off. Flame out during take-off, but no problem. Second flight a log more performance. On booth flights Main Gear remained down. Need help! But a beautifull easy flying model! Reto Senn
I didn't installed another valve on the unlocking pistons, I only soften the static locking springs.
Gear is operating fine on ground in my workshop and in the air.
However, I have to be careful when handling the F18 when radio is off or when air pressure is low, because the locking force of the spring is weaker, but no problem at this time...
Arnaud
Old 06-25-2017, 05:32 AM
  #333
pilot tw
Old 07-06-2017, 07:38 PM
  #334
pilot tw
the F-18 1/6 light set & afterburner rings are avialable now!
ID:	2223271   Click image for larger version
ID:	2223272   Click image for larger version
ID:	2223273   Click image for larger version
ID:	2223274   Click image for larger version
ID:	2223275   Click image for larger version
Old 07-06-2017, 09:11 PM
  #335
pilot tw
F-18F 1/6.25 aggressor more pictures coming soon,.
Old 07-07-2017, 02:12 AM
  #336
pilot tw
RTF F-18f 1/6.25 video coming soon.,
ID:	2223292   Click image for larger version
ID:	2223293   Click image for larger version
ID:	2223294   Click image for larger version
ID:	2223295   Click image for larger version
Old 07-17-2017, 01:18 AM
  #337
pilot tw
F-18f 1/6.25 aggressor finish before package it
ID:	2224677   Click image for larger version
ID:	2224678   Click image for larger version
Old 07-17-2017, 05:29 PM
  #338
FenderBean
FenderBean's Avatar
Anton, I was wondering why the nose gear light is halfway inside the fuselage? Can this be fixed? The gear is a highly visible area and a highlight on the f-18 and for 2600$ this should be correct. I was told this by a previous owner and sure enough after looking at pictures here it looks like the gear is mounted too high in the fuselage.
Old 07-17-2017, 07:33 PM
  #339
pilot tw
yes, you can leak little the air pressure for adjust the nose strust to corectly .,
Old 07-17-2017, 08:19 PM
  #340
FenderBean
FenderBean's Avatar
Hi Anton, im not talking about the strut portion, im referring to the the light on the top part of the gear that is halfway hidden by the fuselage at the top.
Old 07-17-2017, 08:23 PM
  #341
pilot tw
i think this was light position wrong, not the nose gear problem , i will check it out again, Thank you for suggested.,
Old 07-17-2017, 08:27 PM
  #342
FenderBean
FenderBean's Avatar
Old 07-18-2017, 02:59 AM
  #343
Mikey5547
looks great! Very nice colour scheme... Keep up the good work at skymaster!
Old 07-24-2017, 05:26 AM
  #344
pilot tw
F-18f 1/6.25 RTF Aggressor
Old 07-25-2017, 02:04 AM
  #345
Mikey5547
Great video Anton. You should do more vids of jets in the factory it's really interesting to see them close up and walking around them.
Old 07-30-2017, 04:08 AM
  #346
pilot tw
http://www.youtube.com/watch?v=fAt4q...ature=youtu.be
Old 08-05-2017, 01:52 PM
  #347
FenderBean
FenderBean's Avatar
I have a question for people flying one of these or have flown one. I was wondering about CG locations looping31 mentioned add 700grams to the nose from his flight experience with it. Makes me wonder if the stock CG is pushing the bad side of the tail heavy range.
Old 08-07-2017, 05:59 AM
  #348
AU Tiger
Originally Posted by Looping31
Hi all,
Here is a short video of one of the first flights of my SM 1/6 F18C Hornet.
No big issue after these flight tests.
Inflate tyres sometimes grate on the housing and lateral gear doors, I enlarged gear housing and slightly modified gear doors.
With the user guide CG, I had auto pitch at high alpha and I was barely able to escape from a flat spin so I put 700g more lead in the nose cone. It seems to be better now.
Arnaud
https://www.youtube.com/watch?v=Og43...be&app=desktop
Could you post some more vids of your F-18? I love the way you fly it very scale like.
Old 08-07-2017, 06:33 AM
  #349
gunradd
My Feedback: (9)
gunradd's Avatar
Mine felt a little tail heavy from the recommended CG and I was in the process of adding some nose weight before my crash. Its not far off but makes it tough when landing because the plane wants to float real bad.
Old 08-07-2017, 07:34 AM
  #350
Looping31
Looping31's Avatar
Thank you, I will post more videos as soon as possible.
We can't fly since 2 months, our flying field has been invaded by travelers..
Arnaud
