Reload this Page >
It's coming! Skymaster F-18 1/6 on 2016
Old 06-09-2017, 11:47 PM
  #301
pilot tw
test flight the F-18f with full ordinance today.,
Name:	WeChat 圖片_20170610154257.jpg
ID:	2219425   Click image for larger version
Name:	WeChat 圖片_20170610154248.jpg
Old 06-10-2017, 08:34 AM
  #302
pilot tw
http://www.youtube.com/watch?v=EAgmj...ature=youtu.be
Old 06-10-2017, 09:59 AM
  #303
FenderBean
FenderBean's Avatar
this is very helpful since I plan to fly mine with the ordnance like I do my tomcat. Does this model have 160s and do you have any info on throttle usage and or trim changes with the ordnance?
Thanks for the update
Old 06-11-2017, 08:56 PM
  #304
pilot tw
Old 06-13-2017, 04:35 AM
  #305
dubd
dubd's Avatar
Anton, Have you tested the single engine and mid engine version? If so, how did they fly in comparison to the version with the engine in the tail?
Old 06-13-2017, 05:20 AM
  #306
pilot tw
yes, when I test flight the first F-18D blue angel that we installed the single K-210 with separate pipe., the power was enough, but if you want to payload the ordinance , I think you may need more power, I world like the 2 K-160G without the tailpipe. or install 2 K160 in center with the tailpipes.,
Old 06-16-2017, 01:24 AM
  #307
pilot tw
Nice Aggressor color scheme in the RTF workshop.,
Name:	WeChat 圖片_20170616171242.jpg
Old 06-16-2017, 10:55 AM
  #308
Mikey5547
Very nice scheme! Skymaster does very good paint jobs! Will you be doing RTF video like F16?
Old 06-17-2017, 03:15 AM
  #309
pilot tw
yes, good idea, before delivery to customer that i will make some video ., Thank you for suggest,
Old 06-17-2017, 04:49 AM
  #310
Mikey5547
Look forward to seeing it!
Old 06-17-2017, 12:21 PM
  #311
erh7771
My Feedback: (30)
http://www.youtube.com/edit?o=U&video_id=BU1GZ_VYAyE
What is the estimated flight weight of the F-18D with the K-210 ?
Thx in advance
Old 06-17-2017, 06:52 PM
  #312
pilot tw
the single K210 for F-18D 1/5.75 that dry weight should be 25-26kg without the ordinance .,
Old 06-18-2017, 01:01 AM
  #313
pilot tw
Nice 1/5.75 F-18C from Switzerland
ID:	2220553   Click image for larger version
Old 06-18-2017, 02:09 AM
  #314
pilot tw
Likai said only 60-70% throttle used for normal flight , unless for take off, and full ordinance nomore trim changed.,
Old 06-18-2017, 03:51 AM
  #315
jet whine
Default Kt 310
anton,
would the king tech 310 fit in the center of the F-18?
Old 06-18-2017, 04:38 AM
  #316
pilot tw
Originally Posted by jet whine
anton,
yes, perfect .,
Old 06-18-2017, 04:45 AM
  #317
pilot tw
First flight was one Engine take-off. Flame out during take-off, but no problem. Second flight a log more performance. On booth flights Main Gear remained down. Need help! But a beautifull easy flying model! Reto Senn
Old 06-21-2017, 07:15 PM
  #318
pilot tw
Hello
I got this answer yesterday from Anton. I made the changes. Now everything works perfect.
Thanks & Regards
Reto
ID:	2221110   Click image for larger version
Old 06-22-2017, 03:23 AM
  #319
gunradd
My Feedback: (9)
gunradd's Avatar
For those that don't know you will need an extra air valve to unlock the main gear for it to work correctly. The instructions don't mention it along with allot of other things.... but its needed to work in the air.
Old 06-22-2017, 03:34 AM
  #320
pilot tw
Likai said: Does he connect lock cylinder and main gear cylinder together? You must seperate them to two 2-action valves, so there need X3 2-action valves for gear and door system. The sequance for gear-up is : unlock lock cylinder--gear up--close doors . Then reverse this for gear down.
Sorry, we will undate the Manual for F-18 1/6 as soon.,
Old 06-22-2017, 06:16 AM
  #321
Basspilot
Will a up3 valve and distribution block operate this gear system instaed of the jettronics electric vlaves?
Old 06-22-2017, 08:26 AM
  #322
gunradd
My Feedback: (9)
gunradd's Avatar
Yes I used all UP stuff for gear and canopy. Only thing is you will need a separate air valve to unlock the gear.
Old 06-22-2017, 08:48 AM
  #323
FenderBean
FenderBean's Avatar
Thanks, I was trying to figure out what the issue was, does the gear need two valve for the up and down? I had two for the gear on the F-14 to get everything up like it needed.
Old 06-22-2017, 10:10 AM
  #324
gunradd
My Feedback: (9)
gunradd's Avatar
Only needs one UP valve for the gear and one 2 way valve for the unlock
Old 06-22-2017, 11:27 PM
  #325
pilot tw
F-18 1/6 manual updated
http://www.skymasterjets.net/f18xlv3.pdf
