Reload this Page >
It's coming! Skymaster F-18 1/6 on 2016
Old 05-02-2017, 05:38 AM
  #276
dubd
dubd's Avatar
Originally Posted by gunradd
My crash was several problems like most aircraft accidents. The first problem was the RPM interference. The second issue was factory set thrust angles are not correct and shimming is needed. Skymaster has been great with communication on this and they are fixing the problem with instructions how to fix the issue for safe flight. Anton also personally reached out to me privately on this matter and has been great. He is a class act. I hope to be flying another skymaster hornet sometime in the future.
Lets please let this thread get back on track
Thanks for the clarification. That was helpful given I haven't been on RCU enough to follow the details of this thread.
Old 05-02-2017, 05:00 PM
  #277
dionysusbacchus
My Feedback: (25)
dionysusbacchus's Avatar
Originally Posted by RCFlyerDan
Dionysusbaccusus! Wow! Google is wonderful tool. Any twin engine jet or plane can have Asymmetrical Thrust, whether the engines are mounted inside the fuselage or on the exterior of the fuselage, as long as both aren't on the centerline. IF two engines are both running at the same power settings, there is NO Vmc. So! Not irrelevant! Every time Gunradd's F-18 flipped onto it's back, the jet hit Vmc. Your Buddies F15 must have a great gyro with narrow gear and one engine out!
I never stop learning, must be nice to have reached that point in your life. I like the mini resume in the signature block, very cute! You have a bumper sticker made also?
I never said the F-18 was without Asymmetrical Thrust in a twin engine model, not sure where you got that.
My point again is that if the thrust angles are correct, the Vmc is much lower. Safe control of this F-18 was not really possible at any speed on one engine, and you are correct about the tanks and fuel in the case of incorrect engine thrust angles. Anything that slowed the plane at all made it more unstable. BUT it was not the tanks or fuel that did it, it was the thrust angles period.
Rainer Rink is my buddy that flew the F-15 on one engine, I bought that plane from him but have not flown it yet. I was there and saw it, all he said after lift off was "whoa". Do I care if you don't believe it? LOL!!! You must have mistaken me for one of your fanboys.
Old 05-07-2017, 09:54 PM
  #278
pilot tw
good news, the Likai test flight the F-18f 1/6.25 again with the single K-160 for take off and landing yesterday, no problem, Sorry I was no be there so no video.,
ID:	2213853   Click image for larger version
ID:	2213854   Click image for larger version
ID:	2213855   Click image for larger version
ID:	2213856   Click image for larger version
ID:	2213857   Click image for larger version
ID:	2213866   Click image for larger version
ID:	2213867   Click image for larger version
ID:	2213869   Click image for larger version
Old 05-08-2017, 01:19 AM
  #279
mauryr
Originally Posted by pilot tw
good news, the Likai test flight the F-18f 1/6.25 again with the single K-160 for take off and landing yesterday, no problem, Sorry I ma no be there so no video.,
Really nice, I was told the plane flew very safely even on one engine.
Hoping I can put an order in for one in a while, meanwhile maybe you can add this color scheme option? It's a real thing now!
[ATTACH]2213917[/IMG]
Old 05-08-2017, 05:34 AM
  #280
pilot tw
today Likai got an chance to test flight the one turbine for take off and landing again!
From 00:00 to 2:20 this SM F-18F was pushed only by right engine (K-160) and left engine ran in idle. It took much longer runway to airbone. The takeoff weight was 74lb (full fuel).
http://www.youtube.com/watch?v=dG8yP...ature=youtu.be
Old 05-08-2017, 06:15 AM
  #281
pilot tw
High G test flight, powered by K-160 twin ,
Old 05-08-2017, 07:58 AM
  #282
mauryr
Would you say a gyro is a must to obtain such a smooth takeoff on one engine?
Old 05-08-2017, 02:15 PM
  #283
marquisvns
marquisvns's Avatar
Congratulations Anton and LiKai, aside from the lack of power of only one engine during takeoff, the thrust line aiming towards the centerline CG negates the asymmetry of thrust from either engine.
Regards,
Barry
Old 05-08-2017, 02:24 PM
  #284
mr_matt
My Feedback: (10)
mr_matt's Avatar
Regards,
Barry
This all sounds familiar.
So in the full scale parlance, Vmc (Velocity of Minimum control) is all the way down to zero?
Old 05-08-2017, 05:21 PM
  #285
pilot tw
here is Likai's reply as below:
Yes, I use gyros on roll, pitch axis and nose steering. But in this test I only use nose steering gyro and the plane still climb straight without rudder correction.
Old 05-08-2017, 05:38 PM
  #286
pilot tw
http://youtu.be/0Pn6kAurCXg
3:57 hard Landing but no jump , good strusts designed,
Old 05-08-2017, 05:42 PM
  #287
mauryr
That's really great to hear, the climbout was really quite good and if that was achieved without a gyro and even without rudder I think it proves how a correct thrust line goes a long way.
Old 05-10-2017, 11:48 AM
  #288
Looping31
Looping31's Avatar
Hi guys,
Just to inform you that a mu-metal screen between the turbines solved my RPM pickup interferences.
Mid-mounted engines on the F18C are very close from each other.
Ground tests are complete.
Next time, I will maiden.
Arnaud
Old 05-17-2017, 01:35 AM
  #289
Looping31
Looping31's Avatar
Hi all,
Here is a short video of one of the first flights of my SM 1/6 F18C Hornet.
No big issue after these flight tests.
Inflate tyres sometimes grate on the housing and lateral gear doors, I enlarged gear housing and slightly modified gear doors.
With the user guide CG, I had auto pitch at high alpha and I was barely able to escape from a flat spin so I put 700g more lead in the nose cone. It seems to be better now.
Arnaud
https://www.youtube.com/watch?v=Og43...be&app=desktop
Tuggs (02-14-2023)
Old 05-17-2017, 03:17 AM
  #290
Levi Wags
Levi Wags's Avatar
Cool vid Arnaud. I think I need one now.
Old 05-17-2017, 11:29 AM
  #291
JetsRC
JetsRC's Avatar
Nice video, congrats on the maiden...
Old 05-23-2017, 05:43 AM
  #292
Craig B.
haha...like a seagull on a hot chip!
Old 05-23-2017, 06:53 AM
  #293
Craig B.
Nice flying Arnaud. What engines are you running? Are they Merlin140's?
Old 05-23-2017, 07:31 AM
  #294
Looping31
Looping31's Avatar
I'm running 2 Merlin 200xbl on my Hornet.
Take off weight is 33 kg with 8,8 liters of kerosene.
Old 05-25-2017, 03:17 AM
  #295
pilot tw
wow. power by 2 Merlin 200xbl , Congratulations on the maiden , Arnaud.
Old 06-09-2017, 11:29 PM
  #296
pilot tw
Congratulations to Barry , good job!
Maiden of the Skymaster F-18F Super Hornet went well at the Apollo field, with twin K160s at the tail,
had a total of 4 flights today! Barry Hou
Old 06-09-2017, 11:33 PM
  #297
pilot tw
static pictures.,
ID:	2219418   Click image for larger version
ID:	2219419   Click image for larger version
ID:	2219420   Click image for larger version
Old 06-09-2017, 11:38 PM
  #298
pilot tw
Nice color scheme of 1/6.25 F-18f pre maiden with 2x Kingtech 160G2's at the tail / Pilot : Andrew Pohlmann
Old 06-09-2017, 11:39 PM
  #299
pilot tw
Old 06-09-2017, 11:42 PM
  #300
pilot tw
Mario Gomes's Skymaster F-18D 1/5.75 powered by twin K-160G / Pilot: Andre Fly Aero Pupin
