Reload this Page >
Calrl Goldberg Tiger 60 Build
Old 02-26-2018, 09:07 AM
  #301
VincentJ
VincentJ's Avatar
Rick I put the red right over the top of the white, I was too lazy to mark and peel the white away.
Old 02-26-2018, 10:49 AM
  #302
VincentJ
VincentJ's Avatar
Wouldn't you know it I'm one roll short of white. Ordered another roll this morning!
Like Rick say's, you have to know when to stop, that's it for the top of the wing...
ID:	2256207   Click image for larger version
Old 02-26-2018, 12:44 PM
  #303
FlyerInOKC
FlyerInOKC's Avatar
Now you know why I ordered a 10 meter roll of Bright Yellow when I built my 1/5th scale SIG Cub. I still have enough for another airplane too.
Old 02-28-2018, 03:27 AM
  #304
VincentJ
VincentJ's Avatar
Smart move Mike, I didn't want a lot of left over covering though. I don't normally use plastic covering, but it does have its place...
The right wing panel is completely finished. I checked on the delivery of my much needed white, it's due to be delivered today (I paid for 2-day shipping) so work will resume on the left wing when it arrives.
ID:	2256468   Click image for larger version
Old 02-28-2018, 06:27 AM
  #305
FlyerInOKC
FlyerInOKC's Avatar
I bought the big roll about the time a lot of guys where complaining multiple rolls of the same color didn't always match. One long roll prevented that. The hard part was the matching paint but white primer solved that problem.
Old 03-01-2018, 01:00 PM
  #306
VincentJ
VincentJ's Avatar
Update on my Tiger...
ID:	2256572   Click image for larger version
ID:	2256573   Click image for larger version
ID:	2256574   Click image for larger version
ID:	2256575   Click image for larger version
ID:	2256576   Click image for larger version
ID:	2256577   Click image for larger version
ID:	2256578   Click image for larger version
Old 03-01-2018, 01:41 PM
  #307
FlyerInOKC
FlyerInOKC's Avatar
Hatch for under the canopy looks verY neat. Nice idea!
Old 03-01-2018, 03:29 PM
  #308
Leroy Gardner
Their's a different covering theme so far, I don't think your done with it Vince, at this point it needs something more from my point of view but it's your plane.
Leroy
Old 03-01-2018, 11:51 PM
  #309
Hydro Junkie
Hydro Junkie's Avatar
A stripe of some sort going down the fuse would look good
Old 03-02-2018, 04:24 PM
  #310
VincentJ
VincentJ's Avatar
Pretty much at the ARF stage...
ID:	2256648   Click image for larger version
ID:	2256649   Click image for larger version
ID:	2256650   Click image for larger version
Old 03-03-2018, 08:47 AM
  #311
Leroy Gardner
Working in the dinning/ kitchen area cooking up a covering job using some of the utensils for support. It's not going to be gaudy that's for sure, I should wait until you get it done Vince, low key'ed can be a high note.
Leroy
Old 03-03-2018, 09:50 AM
  #312
thailazer
thailazer's Avatar
Vince.. What method (Windex?) are you using to get the top layers of trim on? Sure looks like a great application, and the scheme is classy.
Old 03-04-2018, 01:22 AM
  #313
VincentJ
VincentJ's Avatar
Thanks Leroy, nobody here to stop me ...and it's warmer than my shop.
Thailazer, I am using Windex to apply the second trim coat. The Windex does not soften the adhesive as some have suggested in other threads, but I find that it does a good job in making the trim piece(s) lay down flat. I use a squeegee and remove as much of the Windex as I can, then careful heat management using an iron secures the trim piece in place. By keeping my iron temp between 148-160 degrees I don't make those bubbles between coats of covering. I also find that immediately after ironing, I follow behind with a cloth or mitt to rub the covering in place also helps.
I don't rely on the temp settings on my iron, I use a non-contact infrared thermometer to give me accurate temperature readings.
Old 03-04-2018, 07:50 AM
  #314
RICKSTUBBZ
RICKSTUBBZ's Avatar
Default Applying Trim
Originally Posted by VincentJ
................., but I find that it does a good job of making the trim piece lay down flat. I use a squeegee and remove as much of the Windex as I can, then careful heat management using an iron secures the trim piece in place. By keeping my iron temp between 148-160 degrees I don't make those bubbles between the coats of covering. I also find that immediately after ironing, I follow behind with a cloth or mitt to rub the covering in place also helps.
For applying overlay trim, I do not think there is a better way. I do the same thing except - I usually use my TopFlight trim iron and it does not have a variable heat setting. Either High or Low and of course I use the low setting.
Worth mentioning - the Windex (I am sure there are other liquids that might work) in conjunction with something to use as a squeegee allow you to get rid of the air that gets trapped in the first place. Basically the same practice used for sticky backed vinyl sign material - except the ironing part..
Vince, still looking very clean and "CLASSY". Looking forward to seeing the completion.
Old 03-05-2018, 04:48 AM
  #315
VincentJ
VincentJ's Avatar
Thanks Rick, much appreciated. I'm glad that the covering is completed, once the Tiger is final assembled, I will reevaluate the way it looks to see if adding any more trim to my scheme will improve its appearance.
Old 03-05-2018, 06:04 AM
  #316
Hydro Junkie
Personally, I'd leave it alone. It looks good just the way it is. The only thing I might do would be to add a dark color on top of the nose as an anti-glare panel
Old 03-05-2018, 09:15 AM
  #317
VincentJ
VincentJ's Avatar
Question; does anyone use trim solvent around the edges of their covering? I've never used it and was wondering if I should.
Old 03-05-2018, 09:29 AM
  #318
FlyerInOKC
FlyerInOKC's Avatar
I haven't but my second colors have been small enough I could use trim sheets instead of regular covering. I know some guys shoot a coat of clear over iron on covering to seal the edges. It comes down to personal choice and past experience with covering jobs.
Old 03-05-2018, 02:27 PM
  #319
RICKSTUBBZ
RICKSTUBBZ's Avatar
Vince,
I have used the TopFlight trim solvent on Monokote only. I use a Q-tip to apply. Very little goes a long way. On the occasions I have used it, it was great.
I once used trim solvent to adhere narrow 'frames" of Monokote used to make window trim on a GP Super decathlon. The strips were half on the plexiglass and half on the base color of Monokote. The frames were actually cut as one complete piece using patterns made off of the windows. Obviously I could not Iron on top of the plastic windows. Anyway it worked great. If you apply too much of the trim solvent, you can make a mess. If you look real close at the side windows you can see what I am trying to describe.
Old 03-06-2018, 06:07 AM
  #320
VincentJ
VincentJ's Avatar
Thanks Rick for that info, nice job on your Decathlon!
Old 03-07-2018, 01:24 AM
  #321
VincentJ
VincentJ's Avatar
With an impending storm threatening to dump more than a foot of snow heading my way today, I'm hoping to spend some unexpected time in my workshop! March is always so unpredictable...Guess the snow blower will be in action yet again!
Old 03-07-2018, 04:39 AM
  #322
TomCrump
TomCrump's Avatar
With an impending storm threatening to dump more than a foot of snow heading my way today, I'm hoping to get to spend some unexpected time in my workshop! March is always so unpredictable...Guess the snow blower will be in action yet again!
That storm hit us yesterday. I have 5" of new snow on the ground.
There's another system following. We're expecting another 3-6".
Looks like I will be giving my snow blower a workout, too.
Old 03-07-2018, 06:37 AM
  #323
FlyerInOKC
FlyerInOKC's Avatar
And to think I was complaining about having to put the heater back on this morning....
Old 03-07-2018, 09:13 AM
  #324
Hydro Junkie
DAMN!! You had to put on a heater? I've had my house's heating system up and running since October, been scraping ice and snow on and off since November
Old 03-07-2018, 09:59 AM
  #325
FlyerInOKC
FlyerInOKC's Avatar
I only had it off for two days though.
