Reload this Page >
Calrl Goldberg Tiger 60 Build
Old 02-19-2018, 06:39 AM
  #276
Hydro Junkie
Hydro Junkie's Avatar
Originally Posted by VincentJ
Your caution is well warranted Hydro. My shop air however has water separators which I tend to regularly as well as draining any water that will have accumulated in the bottom of the air tank. Thanks for the heads up, as many would learn about this problem the hard way...
Actually, I learned about it the hard way myself when I got a face full of water through a shop air line and was then told by my employer that THIS WAS NORMAL WITH ALL COMPRESSORS. I later went to work in a compressor shop and learned that my former employer was an idiot that didn't know anything beyond a small block 350 manufactured prior to emission regulations being implemented
Old 02-22-2018, 04:44 AM
  #277
VincentJ
VincentJ's Avatar
Covering has begun on my Tiger. It's going on pretty well, but I have to say that I dislike the job. I would much rather be building a model than covering it. I like using Solartex, but these thin plastic coverings are my Nemesis. There is definitely a knack in doing it well and I admire those that have the talent to do so... Pictures will follow once the fuselage has been completed.
Old 02-22-2018, 06:05 AM
  #278
FlyerInOKC
FlyerInOKC's Avatar
Well covering has begun on my Tiger. It's going on pretty well, but I have to say that I dislike the job. I would much rather be building a model than covering it. I like using Solartex, but these thin plastic coverings are my Nemesis. There is definitely a knack in doing it well and I admire those that have the talent to do so... Pictures will follow once the fuselage has been completed.
Get one of Faye Stilley's old books on covering, he can turn anyone into and expert.
Old 02-22-2018, 08:16 AM
  #279
Leroy Gardner
I suppose there is a knack to covering with film, their not all the same. Having said that, I found Ultra-cote to be the most friendly, heat management is the most important part of it for all coverings and prepping the frame work is just as important. My experience is that small flat jobs are best done with an iron, I don't use a sock on it. When it comes to a radial fuselage a heat gun will work best for me as well as large panels, in most cases surfaces would be sheet'ed when the heat gun is used. Film on film on open structure I use the iron, first film (base film) covers the whole area and is shrunk to tightness before any graphics films are applied over it, generally at application temps of the film being used. In the case of graphics using a heat gun on sheet'ed structure no base film is required, just put the desired pieces (colors) on in a manner that they are lapped to prevent the air stream from getting under them, that applies to all coverings.
Vince your plane will come out just fine because that's how all your work is done. What is perfect anyway, pride can get in the way of perfection on a near perfect job that is perfectly acceptable when looking at the whole job in stead of looking at one little flaw that most others will never see unless you tell them, something else you do.
Leroy
Old 02-22-2018, 09:47 AM
  #280
VincentJ
VincentJ's Avatar
Thanks Leroy. Just the same I wish I had the skills this young woman has...
Old 02-22-2018, 10:00 AM
  #281
VincentJ
VincentJ's Avatar
Mike, I'll have to check out some of those books, thanks for the tip!
Old 02-22-2018, 12:02 PM
  #282
Hydro Junkie
I wouldn't want to be in the same class as her when it comes to applying covering. As I watched her apply the covering, I saw a lot of areas that she took shortcuts that will fail in the not to distant future. The edges were barely stuck down, for starters, the covering wasn't really attached to the ribs either. I didn't like the way she was using what looked like a clothes iron as I heard several times where it sounded like she was hitting the wing and that means dents. Her technique said speedy application, her application just screamed failure
Old 02-22-2018, 12:33 PM
  #283
Leroy Gardner
hydro maniac I saw pretty much the same thing you did, that's factory covering for ya and often the wood work isn't much better. If you want a well built plane build it yourself, there's plenty of help here if you need it.
Old 02-22-2018, 01:25 PM
  #284
Hydro Junkie
Glad to know it wasn't just me seeing it that way
Old 02-23-2018, 10:25 AM
  #285
RICKSTUBBZ
RICKSTUBBZ's Avatar
Cool Covering a wing
https://www.youtube.com/watch?v=XtMbYxEqgiw
Man, there is so much to be said from watching that video.
Yep, pretty much that is how you do it. Except when I compare myself to her, it is as if I am moving in slow motion. Looked like she rubbed all the ribs with that Iron to me?
I have never had the luxury of a pre-printed covering scheme. Then again, I prefer to do one off schemes. So a pre-printed piece of covering is not likely to be available. As we all know, the scheme itself is what takes so much time - drawing and cutting patterns, then cutting the covering, then applying it in the right place so the pattern fits together...
I think it would be safe to say that was not an air conditioned shop... But a nice set up like that sure does make the job easier. Lots of space - no ceiling fan or wall to bang your stuff into. Good clean table (a softer top layer would be nice) all the tools you need right there but out of the way at the same time....That helps a lot.
I can not imagine what it would be like to have to do covering for a minimum of eight hours a day - the same covering scheme over and over...
That girl has hands that are tough as nails! Blowing that heat gun on the edges while pulling that small amount of excess covering to pull out the wrinkles? Man, can't tell you how many times I burned myself trying to pull covering around a corner like that. I am sure that is a lower temperature material than I am used to using, but I still saw the red glow in that heat gun so it's still hot.
Old 02-23-2018, 02:22 PM
  #286
thailazer
thailazer's Avatar
I would like to know what kind of trim knife she is using, not that I would have the skill to use it. Those trims were lightning fast!
Old 02-23-2018, 03:47 PM
  #287
VincentJ
VincentJ's Avatar
Quick update; In order for the covering to continue on the fuselage, the horizontal stabilizer needed to be glued in place. 30 minute Epoxy was used. I was very careful to have previously measured the stab to ensure it was centered on its mount. If you remember, I drilled and installed a couple of dowels to be able to quickly relocate its exact position on the mount once it was removed. This proved to be useful today.
Photo 1- With the stab in position, you also have to verify that it has been installed level in relation with the wings. There are a few ways to accomplish this, but none better than just sighting the stab to the wings. Notice the distance between the bottom of the stabilizer to the top of the wing, this distance should be the same on both sides if the stabilizer is in its correct orientation. I believe the correct term for this is "dead nuts" lol
ID:	2255719   Click image for larger version
Old 02-24-2018, 03:34 AM
  #288
TomCrump
TomCrump's Avatar
With your current pace, you'll soon be hoping for some nice weather so that you can take this bird to the field.
Old 02-24-2018, 03:36 AM
  #289
VincentJ
VincentJ's Avatar
Yes Please....
Old 02-24-2018, 04:56 AM
  #290
VincentJ
VincentJ's Avatar
Photo 1- To prep the stab, I had to mark where the footprint of the fin was using a permanent marker. Don't be tempted to use a pen as it will leave a dent on your balsa. The permanent marker has a softer tip and will wipe off clean using a paper towel wet with Isopropyl Alcohol, (I use 91%). Notice that I cut the covering off 1/16" before the line. This will assure that you will not have removed too much covering leaving an unsightly gap...
Photos 2-3 Again using 30 minute epoxy, the Fin is set into position using a couple of pine blocks that have a 90 degree angle on them to assure the Fin is set perfectly 90 degrees from the stab.
ID:	2255755   Click image for larger version
ID:	2255756   Click image for larger version
Old 02-24-2018, 04:01 PM
  #291
Leroy Gardner
Covering on 3 pieces, well that's a start, the rest will be a piece of cake. Looking forward to more.
Leroy
Old 02-25-2018, 05:58 AM
  #292
VincentJ
VincentJ's Avatar
The weather has turned and it seems as though winter is back. It's snowing with a bit of freezing rain thrown in just to make it interesting if you were to drive...
Oh I have more than those few pieces done Leroy. I got all of the white on, getting ready to put the color accent pieces on.
ID:	2255950   Click image for larger version
ID:	2255951   Click image for larger version
ID:	2255952   Click image for larger version
Old 02-25-2018, 08:07 AM
  #293
RICKSTUBBZ
RICKSTUBBZ's Avatar
Looking forward to seeing what you end up with.
Sure looks classy, clean, and shinny.
Old 02-25-2018, 08:21 AM
  #294
VincentJ
VincentJ's Avatar
Thanks Rick, it's a work in progress, my plans for covering have only changed about a hundred times since I started, so who knows what I'll end up with... LOL
Old 02-25-2018, 08:41 AM
  #295
RICKSTUBBZ
RICKSTUBBZ's Avatar
I know what you mean.
None the less, I have no doubt that your Tiger will look nice when finished.
One of my problems has always been knowing when to quite.
I have made more than one look a bit gaudy because I put to much 'trim" on it.
Old 02-26-2018, 03:24 AM
  #296
VincentJ
VincentJ's Avatar
Thanks Rick, I'll try to stop before that happens...
Things are progressing very slowly, I'm no speed demon but progress is progress! Took me the better part of the day just to make a pattern, and get it on one wing panel.
ID:	2256184   Click image for larger version
ID:	2256185   Click image for larger version
ID:	2256186   Click image for larger version
Old 02-26-2018, 03:38 AM
  #297
TomCrump
TomCrump's Avatar
It's not a race. It's better to take your time and get things to your satisfaction.
What you have looks great !
Old 02-26-2018, 06:23 AM
  #298
FlyerInOKC
FlyerInOKC's Avatar
Looking good Vince!
Old 02-26-2018, 06:58 AM
  #299
RICKSTUBBZ
RICKSTUBBZ's Avatar
Hey Vince,
By looking at the pictures, I can not tell- I can't see an overlap line. Did you cover the whole wing in white then add the trim? Just curious...
When I do solid surfaces (fully sheeted) with similar trim schemes to yours, I will trim the base color leaving about 1/4" of overlap for the next color to lay on top of that.
Old 02-26-2018, 08:49 AM
  #300
flygilmore
flygilmore's Avatar
I didn't watch the vid but I've seen vids of Extreme Flight workers applying covering. From what I've seen, they can cover better than 99% of any other modeler out there. Sure, it's easy to point fingers at these folks and whatever "shortcuts" they may be taking but at the same time, ARF's are "cheap" for a reason. Do you really think that you would be doing things differently if you were in their shoes doing this for 8hrs.+ a day???????
Doesn't bother me either way though as I am a kit and a scratch builder having only owned a couple of Electric ARF's in the past.
