Welcome to Club SAITO !
Old 12-27-2008, 08:22 PM
  #13301
mike early
mike early's Avatar
Default RE: Welcome to Club SAITO !
ORIGINAL: chashint
Saito 125 ......
Prop, RPM, and nitro information would be great.
http://www.rcuniverse.com/forum/m_36...tm.htm#3678472
there ya go!
Old 12-28-2008, 12:18 AM
  #13302
chashint
Thanks for the link, I appreciate the info. [sm=thumbup.gif]
Old 12-28-2008, 12:13 PM
  #13303
sodbuster 1
sodbuster 1's Avatar
ORIGINAL: mike early
They might have used 30% for those numbers, because it seems those boys at Horizon like 30% quite a bit.
Be patient and your 125 will continue to get stronger for many many gallons. I was once in your boat.
I spoke to Horizon a few months back about fuels.......
The ONLY fuel they use is 30%.
Nice to not have to pay for your fuel, huh?
Old 12-28-2008, 01:04 PM
  #13304
Garthwood
And the drama of what fuels to burn continues.............a never ending subject. There's so much written on different threads already and manufacturers alike that we can learn from. What a waste of energy, some can't let go off the subject. If you own a Saito and their manual, no need to look elsewhere. If one stores fuel in hot and damp areas, and an occasional flight no need to complain, dump that fuel because all you have is water. Left over from one season to another should never be used. What ever the experts (there are so many around) tell you. Just my 2Cents. End of subject please.
Old 12-28-2008, 01:07 PM
  #13305
dirtrod
dirtrod's Avatar
Thanks BLW,
Proud to be a member. Just to let everyone know i flew the twist 40 sat, with the rebuilt saito .65
it could not have run better i guess thats why i have two .65's. thanks to W8YE for the advice.
I dont want to bragg to much but yesterday was 67 deg sunshine and winds 3-5, man it was beutifull!!
have a great day,
Ty[8D]
Old 12-28-2008, 09:52 PM
  #13306
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
Yessir, the weather yesterday was great. I flew my 1/3 J-3 Kitten w/ Saito 2.70 twin yesterday and thoroughly enjoyed it Spent the afternoon practicing one wheel touch-n-goes. The 2.70 ran like a top.
Old 12-29-2008, 01:41 AM
  #13307
Slats!
Hi, Can anyone confirm what comes in the tool kit for the 1.00. THanks
Old 12-29-2008, 01:46 AM
  #13308
w8ye
My Feedback: (16)
w8ye's Avatar
http://www.horizonhobby.com/Products...rodID=SAI6596A
Old 12-29-2008, 01:53 AM
  #13309
Slats!
Thats great thanks, I had a valve cover nut come loose and fall out would that be a concern or a normal thing.
Old 12-29-2008, 01:56 AM
  #13310
w8ye
My Feedback: (16)
w8ye's Avatar
Not of any great concern but I would plan on replacing it before Spring
Old 12-29-2008, 10:57 AM
  #13311
VF84sluggo
My Feedback: (55)
VF84sluggo's Avatar
ORIGINAL: blw
ORIGINAL: VF84sluggo
What's the proper way to store fuel? I may just go ahead and get a case. What the heck, on less thing I'll need to worry about a trip to the LHS for.
Out of direct sunlight, temperature controlled if possible, and humidity kept under control. I leave my jugs in the box and store the box in a locker type of enclosure. I used to leave the fuel in a closet before that.
Thanks for the info. Here in Florida, this may be a bit of a challenge. A closet in the gagrage will be ok in the winter, but the summer heat and humidity will be a concern. No way will the wife let me keep this stuff in a closet in the house...unless I can hide it somewhere
Oh, may I join the Club? Got a Saito 100 in a H9 Hellcat.
Old 12-29-2008, 11:27 AM
  #13312
pmillerusa
pmillerusa's Avatar
... another fuel question... I was able to pickup some Power Master 20/20 they label as for YS and Saito. This is 100% synthetic and looks like it would be in line with what Saito recommends in their manual. (it is higher Nitro than they recommnd however)
any issues with this Fuel? $20.00 a gallon seemed like a good deal if it'll be ok to run.
I searched and saw others using this in both Saito and YS engines.. just looking for a confirmation.
Hey, and can I get a membership as a new Saito owner...?
Old 12-29-2008, 11:55 AM
  #13313
w8ye
My Feedback: (16)
w8ye's Avatar
The fuel will be OK in your Saito.
It has more synthetic oil than regular synthetic oil fuel
Old 12-29-2008, 12:09 PM
  #13314
leedees
leedees's Avatar
I am having a problem, I hope someone can help.
I picked up a brand new Saito 56 GK, my first 4 cycle. I mounted the engine in my 80" Hangar 9 J-3, replacing an Evolution 46.
Trying to break in the motor, I am having a problem keeping the engine running. It will start after priming and run 3-4 seconds until the prime is exhausted. Re-priming equals the same problem, starts then stops. Needle valve is open 2.5 turns per the manual, I have tried it open another half turn and closed another half turn.
It doesn't speed up like it went lean, it just slows down and stops.
Glow plug good and also tight, new fuel, igniter charged and left on the engine after starting, fuel line has all been replaced and there's no bubbles in the fuel. Even removed the fuel filter and ran straight fuel line. Pressure line is a little long, about 5 inches but it has been replaced too.
It is a two line fuel tank and fuel will flow out of the feed line by gravity alone.
Very grateful for any suggestions.
Old 12-29-2008, 12:22 PM
  #13315
w8ye
My Feedback: (16)
w8ye's Avatar
You may have the two fuel lines to the tank crossed. In other words, the vent line is hooked to the carburetor rather than the muffler.
The engine crankcase vent must be open to the atmosphere
Old 12-29-2008, 01:40 PM
  #13316
Garthwood
If it's Nitro/glow fuel you are refering to, I store my Power Master fuel down the basement, summer or winter at (between 65 to 68 F)
Tightly in their 6 cans to a box. I also use one of these big plastic storage containers that holds at least 6 cans at Comfort humidity
38% to 45% relative humidity. In the summer time I run a dehumidifier in the basement. In our house we have to run aircon. because of hardwood floors. I never store fuel in the garage, because it is either too cold or too hot up here. At the field I keep my fuel can in the shade. It's quite safe to store in the basement. I stayed with Nitro /glow fuel for that reason. I would like to fly gas, but because of the gasoline fumes that leaves in a car while transporting to the field. The misses will find something to complain about, which I don't blame her a bit.
Old 12-29-2008, 02:16 PM
  #13317
leedees
leedees's Avatar
Thanks w8ye, I'll check the things you suggest.
LHS guy suggested checking crankcase bolts and head bolts which I'll also do.
I'll report back when I discover the issue.
Old 12-29-2008, 03:20 PM
  #13318
VF84sluggo
My Feedback: (55)
VF84sluggo's Avatar
ORIGINAL: Garthwood
Oh, come on, work with me here!
Old 12-29-2008, 05:15 PM
  #13319
jdkxtreme
My new .82 says start 4 turns out
Old 12-29-2008, 05:27 PM
  #13320
Rudolph Hart
Rudolph Hart's Avatar
Your engine talks to you too?
Grab a glo stick and flick the prop.If it's anything like mine it will settle down after a couple of litres.Godd luck and enjoy.
Old 12-29-2008, 05:31 PM
  #13321
Rudolph Hart
Garthwood try adjusting YOUR main CHW needle..(can't hear wife)
Old 12-29-2008, 05:53 PM
  #13322
jdkxtreme
Sometimes I think they mock me.. Like when they won't start for no reason..Just got 3 tanks in the 82..Was going to work on the lsn but got dark outside
Old 12-29-2008, 05:54 PM
  #13323
Falcon32
Falcon32's Avatar
Hi Guys
I’ve got a Saito 100 in a Fliton Extra Freestyle (I love that combo B.T.W.) which has recently become a P.I.T.A. Maybe something to do with the temps here in the U.K. just 2 or 3 degrees above freezing.
My setup is: 30% heli fuel, cline regulator, 15X6 A.P.C. and it’s had about 8 Gallons use.
My usual procedure is to leave the glow igniter on for about 30 seconds at a high idle and then to check the transition to W.O.T. Then taxi out to the take off point blipping the throttle, then without fail she will throttle up take off and fly without missing a beat.
Two weeks ago, same procedure, but the engine cut on the take off run. Brought it back to the stand and it restarted instantly. This time it cut before I could get to the take off point. After doing this twice more I finally got the plane into the air where it performed perfectly.
I had three further flights that day with the same problem every time. Same thing this Sunday. It seems the hotter it gets the better it runs.
Maybe I need a new plug maybe the valves clearances need adjusting?
I have adjusted the valves a few weeks back using the gauge supplied by Saito, but I have heard that this gives too big a gap, what should the gap be? Someone at the field suggested the exhaust should be a bigger gap than the inlet due to it getting hotter, is this correct?
I would really appreciate some help from the guys that know.
Thanks in advance.
Old 12-29-2008, 06:08 PM
  #13324
Rudolph Hart
Try not to lean the lsn too much yet and run another couple of tankfulls thru it
Old 12-29-2008, 06:39 PM
  #13325
Garthwood
Keep the boss happy[sm=lol.gif], I say.
