Walbro Metering Needle
Old 01-19-2018, 05:32 PM
All Day Dan
All Day Dan's Avatar
Default Walbro Metering Needle
I have two of the Walbro K20-WAT rebuild kits. They are dated 05 2011 and 08 2013. They both have metering needles without the rubber coating on the tip. Is this the new normal? Dan.
Old 01-19-2018, 06:01 PM
cbaker65
cbaker65's Avatar
I wouldn't think it matters unless there is a lot of pressure built up in the tank .in which you can install a breather valve!
Old 01-19-2018, 06:29 PM
Truckracer
My Feedback: (19)
I always keep a number of K10 and K20 kits in stock and the ones I have here have dates between 2013 and 2017. They all have the rubber tipped needles. I have not seen a plain tipped needle since forever. Are your kits genuine Walbro?
Old 01-19-2018, 06:44 PM
CK1
My Feedback: (60)
CK1's Avatar
Dan , I know this may sound odd but ....
are you sure the tip is not silver color over the rubber tip ? I have noticed a silver coating on some needles that makes the needle appear solid. Push gently in the tip to check so as not to deform it.
Old 01-19-2018, 07:55 PM
All Day Dan
CK, you hit it right! I should have known. It is a flexible material that is silver colored. That's the first time I have seen such a thing. Thanks for all the responses. Dan.
Old 01-20-2018, 07:53 PM
All Day Dan
I ran the engine with the silver colored metering needle this afternoon. It started right up and responded normally I also picked up two more rebuild kits with a date of 10/21/16 and they have the silver colored metering needles. Dan.
Old 01-20-2018, 08:04 PM
CK1
My Feedback: (60)
CK1's Avatar
I noticed the silver coating starting about 10 years ago on the Walbro kits and soon after on some of the Stens kits . The coated tips always seem to work and I have noticed no stuck needles like happens on the uncoated needle tips . I think the coating is actually teflon or something similar
Old 01-20-2018, 10:59 PM
Truckracer
My Feedback: (19)
Interesting! I noticed the light silver color but they were still a soft tip so never thought any more about the needles. They've been that way for quite some time now.
