Making Molds of Classic Pattern Plane Fuselages & Parts to Keep them Alive for all of us to Enjoy!
#76
QC, CANADA
RE: Making Molds of Classic Pattern Plane Fuselages & Parts to Keep them Alive for all of us to Enjoy!
ORIGINAL: frequent flyer
Building Fiberglass fuselages for the Wild Beat, Aurora 60 & the MK Beetle.
What are you thoughts for these? I had planned to build fuselages with plug in wings so I can add wing adjusters . I would also have foam core wings. Easier to stuff ion the car you know.
I posted my thoughts/comments on the plug-in wing glass/foam kit concept on Tarquin's Beetle build thread. In retrospect it would have been much better to post those comments here. In short, I agree with your line of thinking. In particular, I like the idea of plug-in wings as it will make the fuse molding and layup easier for you (two piece fuses) as well as allow "wing stubs" to be molded into the fuse. I think the way to go about the fuse plug might be to build a wood fuse as if it were a glass one with the two plug-in wings. You can then add the wing stubs to the fuse to produce the final plug desired.
The easier it is to build the model, the better. Plug-in wings with pre-drilled cores for wing joiner tube as well as servo leads would be a plus. Getting into cutting the cores with the retract wells is something that perhaps might take too much time and labor on your part but if you can find a way to "automate" that, that would be a great plus. I enjoy doing that kind of work but not everybody does and it might move kits off the shelf a little faster to cover the costs of tooling. Just some ideas.
David.
#77
David
You bring up a good point about the retracts. I guess if I did the plug in wings design one would be limited to air or electric retracts. Mechanical may be a little tough to connect linkage with a two piece wing.... Do you think that most people would be going the route of Air or Electric?
#78
ORIGINAL: crankpin
I just found this thread, everything see is good, or great. Plug in wing's on the classic birds, and wing adjuster's ? Certainly a plus. Are you making kit's, etc., on request ?
Crank
Crank
My aim is to eliminate this problem by offering all of these items. As time allows. This is a hobby, although I probably spend far more time in it than most. If you have question about a plane or part you can email me or PM me.
#79
My Feedback: (18)
GA
Using mechanical retracts on plug in wings is not really a problem. I use those ball/socket connectors and it's no big deal at all.
I figure most folks will buy pneumatic or electric retracts for their project these days, I just happen to have a few sets of mechanical retracts on the shelves so I wanna use them up.
#80
QC, CANADA
David
David
retracts on a plug-in wing are not really an issue. The main concern is to make sure that the joiner tube provides sufficient stiffness to handle the stress of landing but of course you know this. Most builders I suspect would build a glass/foam kit using either electric or pneumatic gear but even if one used mechanicals, it can be done with a plug-in wing.
Check out Jeff's plug-in Aurora scratch build thread and you'll see how he used mechanicals with a single servo mounted in the fuse. I would venture that it is actually easier to use mechanicals with a plug-in wing than it is with a single piece wing. Here's why: with the single piece, the servo has to be mounted in the wing center. Rigging the nose gear pushrod off this servo is quite tricky although it used to be done frequently in days bygone. Nowadays it makes for an easier setup to use two servos. With a plug-in wing, one can actually install the pushrods into the wing panels with a quick disconnect linkage (e.g., Sullivan ball links). The servo in the fuse is rigged permanently to the nose gear while the wing panels have their pushrods clipped into the servo wheel on attachment. The fact that one has access to the fuse radio bay with the wings attached makes for a much easier connection process. Once all is connected: gear, aileron servos, air lines, etc., the belly pan is installed.
Whatever the case, the plug-in wings pose the most difficulty in their interface to the fuse sides. Other than that, they are very nice to deal with in my opinion.
David.
#82
Don,
If you decide to go with the plug in wings on the Beetle look at the Summit III fuse as how it was done.
One of the early designs that I can remember having plug in wings.
#85
After a long process of body work on the plug. I have now completed the mold of the Bootlegger.
#86
My Feedback: (21)
ORIGINAL: dwaynenancy
Has anyone ask for a TigerTail fuse? Dwayne
I offered my TTIIIsome time back, didn't seem like much interest but it would be nice to have it should the interest rise.It's got the tail feathers on now so it won't help; do you have one that Don could use if the interest is there?
hook
#87
My Feedback: (62)
I used to have a Southern R/C kit but I gave it to Ralph DePalma in California. He had some fond memories of the TT with his father. A friend of mine is flying one in San Antonio. It came out in Model Airplane News right after Ron won the Nats.
#88
Thank goodness. Got any time to fly next week?
Chris...
Chris...
#89
I'm working on it. I spent alot of time putting together a computer to run my cnc hotwire table. I got that done. I had to build two more glass fuselages...done. I worked on the giant ugly stick .....almost ready. I'm tring Chris......I haven't forgotten.
#90
Cool. I noticed the wind is coming up tomorrow so maybe Thursday?
I'll call. My Super Chipmunk TOC thing fell through. Looking for another.
Chris...
#92
when you make a plug out of the original do you loose the original I have an Atlanta 60 that was flown at the NATS in the mid 80's, about 5 years ago I was landing dead stick down wind at high speed and cliped the runway light and cracked the body at the rear thought about patching it but would be to weak to fly.
#93
Hi Folke 190
No, the original is not damaged if it is new and if it was a repaired used subject the only thing that has happen is some of the primer coat that has been applied may peel. But basically nothing to the original. I've been wanting to do the Atlanta for a long time. Do you want to use it as a plug?
#94
Hi don here are some pics of the Atlanta and the crack in the body:
#95
That's not bad and can be reinforced on the inside. If using it for a plug to make a mold I will need to wet sand and fill the outside to make it perfect, every little thing shows up in the mold. Let me know what you are thinking. Do have any of the plans for the stab and wing size,rudder, airfoil, etc. so I can set up my cnc foam cutter to cut additional cores?
#97
I wish I had that one . I need to find someone with an original fuselage to make a mold. Do you know anyone? I do have an Aurora 60 belly pan, canopy and form cores. But not for the Aurora 90.
#99
QC, CANADA
Chris,
that sounds easier than it is. Enlarging the plans doesn't automagically produce a laser cut kit... it takes considerable work and time. If you've been there, I'm sure you know.
I've actually picked up the considerable work done by a fellow member on the CAD drafting of the Aurora. However, I have no plans to finish it soon - it's a "when inspired" project.
As Paul pointed out though, there is no larger Aurora 90. What does exist is a modification to the plan to install a four stroke 90 instead of the conventional 2 stroke 60. With 60's like YS's and Hanno's, substituting for a 2 cycle 90 is not particularly desirable (at least to me). There are not that many 90's which have the same kind of options and performance as the pumped 60's. Besides, a pipe for a 90 would likely not fit in the design of the model.
Do you want to scratch build, build in wood from a laser kit, build a wood fuse/foam wings or glass fuse/foam wings?
If you narrow it down, you might get some more focused help.
David.
David.
#100
ORIGINAL: Chris Nicastro
If you have plans I have a buddy that has a laser cutter...enlarge the plans and go from there. Viola, laser cut kits!
